Hello cruisers,
I decided to create a build thread on my 1982 FJ43 I acquired a few years back. The vehicle was in drivable condition but with a poor quality driver level restoration yet a good paint job and no major rust issues. Essentially a pig with lipstick. I decided to pull the trigger and fix all the mechanical issues along the way and build her under the following provisions: keep her Toyota, upgrade to some modern creature and safety comforts, and take a few liberties that would allow me to incorporate some of the best Toyota had to offer for the FJ40 series. This is her story.
The good:
Body was in good shape and she was essentially complete. Nice paint job but not my favorite color.
She came with a Warn 8274 winch and 33” tires
Original strong running motor with about 89,000 miles with matching drivetrain.
The bad:
The electrical was a mess...spliced wires, nothing original, some shorts...basically a complete redo
The suspension was beat to hell from back roads in Columbia. Required the front and rear perch springs to be cut off and replaced.
Carb was missing parts but got the motor running
Drum brakes all the way around...and half of them dragged.
Parking brake had wrong length cable from fj40 and didn’t work correctly
Rear drum brakes not salvageable.
The ugly:
The frame had some cracks that were expertly covered up with bondo to hide from the next owner (me) which I’m still pissed about.
The front left wheel wallowed down the road due to a loose something that couldn’t be pinpointed....not safe to drive
Objectives:
Frame off restoration, swap the 4 speed transmission for an H55F 5 speed, install front disk brakes from an FJ60, redo the entire brake system, OME 2.5” lift, 16” rims with either 235/85r16 32” tires or 255/85r16 33” tires (still debating), and redo the electrical utilizing some features from later FJs like back lit choke switch, lights, etc. and keep her classic and give her a new look. Final exterior color will be revealed this spring...hint, it’s not yellow.
The good:
The bad:
The ugly:
Objectives:
