1982 FJ40
Florida
The last two times I drove my FJ it was hard to start, kept running (very rough) after I turned off the ignition, and you could smell fuel fumes after it stopped. Can someone please advise what may be the issue. I was thinking it may need a tuneup but the fuel smell after shutoff is a concern. Thanks in advance.
So to get help here it’s gonna be in the details. So it starts hard, once warmed up it runs fine? Is it driven regularly, or just once a month? Etc.
It runs fine once it’s started. It doesn’t have AC, and I’m in Florida, so I tend not to take it out as much in the hot months. I may drive it once every 4-6 weeks in the summer.
So if you drive it that infrequently, l’d suggest you top off the fuel tank with non ethanol gas ( if it’s available ) for starters and continue using it. Do you know the true miles?
Thanks. I will follow that suggestion. It has 131K miles. Greatly appreciate the help.
Has it always been like this?
Yeah they always run better if you regular drive them. Might need a carb clean/tune up, fresh fuel like he mentioned.
Are you mechanically inclined or do you have a mechanic that knows his way around old landcruisers? Have you poked around under the hood and done a visual inspection? How about some pictures, pictures are really helpful.
Thanks to all for the help. I’m not very mechanically inclined and would probably make things worse by attempting to fix it myself. I ran it again this afternoon and did not have the same issue. There was a small amount of sputtering after shutoff but nothing like yesterday. I think my LC (like me) may just need more exercise. Here is a photo. Thanks again for all the help.
