1979 BJ40 Build
The hard top used on this build came off of a older hatch style cruiser. The original hard top was beyond repair once I got it back from the media blaster.
Installed the lower door hinges of the ambulance doors to the tub in order to scribe the location of the upper hinge on the hard top..
As you can see from the previous post the pinch weld has been shave along with the tub pinch weld. This is a resto - "Slight" mod. I believe a cruiser should still look like a cruiser at the end of the day or it isn't a cruiser. After all, it's cosmetic styling is part of why we love these old tractors..
Hello,
what is the volume of the tank?
Good job, good welder!
Sam
It's a 21 gallon fuel tank from Man-a-fre... It's a little on the expensive side but very nicely built, and the fitment is also quite nice..
Thank you:)
A few shots of the hydro Boost brake master assembly mounted on the firewall. I am eliminating the stock Alternator with vacuum pump for a 14 Amp 12 Volt GM Alternator (Cheap and easy to source). This hydro boost unit will run off of a saginaw pump that will also power the saginaw power steering box in series.
