Backfiring through the carb is often incorrect timing. All the unused fuel misting about says incorrect timing to me as well.
You need to set the flywheel to the BB - not the line - otherwise you'll be too retarded to run well. Make certain you're not 180º out of time as in one full rotation of the crank (360º). Set Cylinder No. 1 to TDC as best you can by confirming that both valves are closed. Next aim your rotor at the No. 1 contact inside your distributor cap. It doesn't matter which spark plug you're pointing at as you can use any wire as the No. 1 or the distributor can be rotated to any convenient position. It's just conventionally been done with the distributor in a particular position for assembly line consistency. I ran an HEI distributor for years that was rotated about 90º from a "normal" position. I just used a different connection on the cap for the No. 1 wire and pointed the rotor directly at it to get it started and then followed up with a timing light.
Yes, you can choke the carb. Most 2Fs are hard to start without a little choke. Confirm that you're seeing the accelerator pump squirting fuel into the throat by looking down the primary bore and actuating the throttle linkage with your hand - engine off of course.
I don't recognize the procedure you used to check for compatible coil resistance. Going from memory (?) all you need to do is disconnect everything from the coil and check resistance across the two studs. If it's too low add a ballast resistor that brings the total resistance into spec or the Pertronix will fry. If too high you'll need a different coil or the Pertronix will misfire.
