bwell
I followed pin heads carb tutorial and went through it.
I got it started yesterday on its own with a new battery, new negative wire attached to cleaned up ground connection on the frame. Initially the gas bowel was over filling and running out the primary when engine was turned off but that stopped once I got the idle adjusted and ran it for awhile. Choke settings are working great.
I need some suggestions on where to start. Once warmed, it falls on its face with any kind of throttle input other than very slight throttle input it will eventually rev up.
Do I need to focus on finding vacuum leaks first? I was planning on following the guidance in a few older threads using the cardboard of the carburetor inlet to start.
I'm sure something is off with the ignition somewhere it doesn't idle like it should. I know when I tested the secondary diaphragm assembly depressed all the way against the back it would pop out to its intended shape but hold until I released the inlet.
I put the jets back in the exact way they came out. It always ran great how it was assembled after he rebuilt the carb years ago.
Jet primary- 36
Jet sec - 171
Jet primary slow 75
Jet sec slow 10
To me the slow jets seem like they're reversed.
Any help or direction would be helpful. Not trying to throw a fortune just getting it running right.
Jet primary- 36
Jet sec - 171
Jet primary slow 75
Jet sec slow 10
