1976 FJ40 - Pittsburgh, PA $1500
Pittsburgh, PA
1976 FJ40 - Pittsburgh, PA REDUCED to $1200
1976 FJ40 for sale. I just bought this a little over a month ago and I decided to look for a better starting point. Tub isn't too bad, because it looks like the quarters and the wheel wells were replaced at some point. Needs a frame or someone who can weld. Currently not running. Harmonic balancer needs to be installed, but the key on the shaft is broken off. PO said that it ran prior to that. Mileage shows 66,500. Will need brake lines I'm sure.
If someone wants to put the motor back together and weld up the frame, you may be able to get some use out of this. Otherwise, I think it has some good parts that are salvagable.
I'm in Pittsburgh, PA.
pabigbucks@comcast.net
Thanks!
Dale
Thats a neat way to mount the turn signals.
Coming down south any time soon??
I'm looking for a tub and parts that I can work with ....what's the floor like as far as rust? I'm in Mi. Thanks Mike I have toyota truck parts....any trades call me 616-886-1869
What is wrong with the frame? Are the rails bad, the rear channel? Have any pics of that?
Do you have the rear jump seats?
I am interested, AND in PA ;-)
CAZ
Passenger side where spring mounts is toast. The rest of the frame is scaly, but I haven't poked much.
I have the rear jump seats.
I will try to get pictures this weekend.
This thing is getting parted out soon.
interested in some parts if you are parting out...front axles (only if they are disc brakes)...front seats...thanks...Roger
