How do I adjust the front brakes?
Thanks Brian.the procedure is in the FSM, it's also the same as the rear.
adjust them in till they are tight, then back off 3-4 clicks.
@sparkelzap , welcome to Mud! I recently contributed to a different thread on this topic, so my answer I quoted above was for the rear brakes on a 78-79, but the principles still apply. The same procedure applies to front drums on a 75. If you do a search on brake adjustments, there is a ton of information. @Coolerman has a really good writeup on his website as well. Also, have you bled your brakes completely?Already lots of good advice on this thread from folks that know what they are doing. I'm a hobbyist, not a pro, so I will only try to add what I have learned doing this on my 79 rear drums (which should be identical to your 78's). It's important to get BOTH wheel cylinders adjusted tight on each drum. It's easy to fool yourself into thinking that a drum is properly adjusted when, in fact, only one of the two cylinders behind it is properly adjusted. In this situation, one of the two shoes is dragging nicely, but the other cylinder and shoe on that drum is still too loose. If this is happening, it will cause the symptoms of a soft pedal and 2 pumps to firm it up. I'll try to describe what I have done in order to get them adjusted properly:
1. I pick one side of the axle to start and complete this procedure before moving to the other side. Before I install the drum I will expand the wheel cylinders out as much as possible by hand, and still be able to barely slide the drum on. This minimizes the amount of adjustment you need to do on your back with the adjustment tool.
2. With the drum installed, using the adjustment tool through the backing plate, expand a SINGLE wheel cylinder until it alone locks up the drum from turning. Then back it off 2-3 clicks, no more (Start with 2. If it's still locked, go to 3). You should then be able to spin the drum with considerable dragging of that shoe.
3. Then, expand the opposing cylinder on that same drum, until it locks up the drum again. Then back it off 2-3 clicks, no more (again, start with 2. If it's still locked, go to 3). Your drum will feel tight with considerable drag, but if you mount your rim and tire on it for more leverage, you should be able to spin it 360.
4. Repeat steps 1-3 of this procedure on the other side of the axle. After you do this on both sides, go for a short drive and check for heat. You WILL smell a little bit of warm brake lining for the first 5 miles or so, but it should not be "burning". If it's too hot, then you can back off both cylinders by one click (no more), and repeat the check for overheating. This technique has worked for me, and should also provide you with a firm pedal.
Credit for everything I have learned on this topic goes to Mark A @65swb45 , and Coolerman @Coolerman . Thanks for their wisdom and mentorship.
Thanks!@sparkelzap , welcome to Mud! I recently contributed to a different thread on this topic, so my answer I quoted above was for the rear brakes on a 78-79, but the principles still apply. The same procedure applies to front drums on a 75. If you do a search on brake adjustments, there is a ton of information. @Coolerman has a really good writeup on his website as well. Also, have you bled your brakes completely?
Is there a video to see on actual adjustment? The holes in the back are so tiny.@sparkelzap , welcome to Mud! I recently contributed to a different thread on this topic, so my answer I quoted above was for the rear brakes on a 78-79, but the principles still apply. The same procedure applies to front drums on a 75. If you do a search on brake adjustments, there is a ton of information. @Coolerman has a really good writeup on his website as well. Also, have you bled your brakes completely?
