1974 FJ40 Nor Cal
Corning, CA
I have a really nice '74 Cruiser. Here is what it has:
Chevy 350
3-Speed Transmission
4.56 gears
Front Disc Brakes, Rear FJ60 Axle
Front Aussie Lockers
Leaf Over Lift
Power Steering
This cruiser gets about 14 mpg, which is pretty good for a lift FJ40. Motor runs solid and has a Weber Carb. I have ran this rig in the snow and it does very well. Rig comes with the soft top and hard doors. $5000.
Bump^^^^^^^^^^^^^
$6000....Bump.....
Update, this only has one Aussie Locker in the front. The Rear Axle has an Open Diff. Tires are 35x12.50 BFG All-Terrains on 15x10" Chrome Wheels. Needs some body work and better paint and it would be an excellent rig. I have a roll cage for this if the owner wants it. The cage needs some additional work, but it is a good start.
$5500....bump.....
What's the rust situation?
The rear quarter panels are thick steel, which were intended to cover over rust issues in those areas. The drivers side floor board has a few spots that are pretty bad. Personally, if I were to keep it and do a better paint job on this rig, I would replace the drivers side floor board and POR-15 the entire tub (top and bottom) and it would be perfect.
Despite the rust, this is a good deal on a pre-smog FJ40 that has a lot of the difficult mods already completed.
Bump^^^^^^^^^^^^^^
Bump............................
