If your carb has the EGR provision, it is a Calif model. Carb is taller because of the tube between the float bowl and the throttle body. And I think only the Cali spec carb for that year has the ported vacuum nipple for vacuum advance.
Use SORs carb identifier to see what you have
The only reason I mention this is the fuel tube (pipe) will need to have a 'taller' bend to reach the taller Cali spec carb inlet. But calling RedLine should let you know if theirs will work. If it does, let us know. I need one, too.
Toyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
www.sor.com
