1973 Fj40 wiring harness questions
Santa Maria CA
I had a rat chew through my main harness this winter, it chewed every wire were it ran through the firewall to the engine bay. I have most of the wires back to were they belong (besides the lights and horn) but I am having trouble on a few. I have traced the BY wire to the coil but there is one more BY coming from the rear harness in to the engine bay. I also have this plug that was chewed completly off in the engine bay right under the fire wall gromit.
Just a little lost on the BY wire coming from the rear harness. does it tie into the 3 wire or does it go to something else. On the wiring diagrams I can not find a BY in the rear harness.
The Fj40 is a December built 1973 de smogged.
Everything worked as it should until this rat bastard came along.
Thanks for any help.
Coolerman sells factory style plugs and terminal ends. Black yellow is the ignition circuit. Wires likely go towards and around the coil.
A word of warning, those heat shrink splices don’t last more than a year or so. You will be re-doing them.
When we have damage like that here at the shop we replace the entire wire terminal to terminal. It is a ton of work but worth it for trouble-free connections.
