1972 FJ55
Good luck on the rear brakes. Most of the M/C units are super finicky running all 4 wheels. If this set up works, would be curious what M/C you upgraded too.
Nice rig!!
Hoping you guys can help me out here, the pig is finally home from the shop with all the bodywork fixed, rebuilt carb, new wires, plugs and alternator, she is running like a champ attached some updated pics
I am now trying to get all the windows and door locks working
I noticed that that the nipple on a few of the regulators is all stripped out, does anyone have a solution for this?
I am trying to remove the window crank. How did you get it off?
Nookkidzz,
Between the door card and the crank there is a C clip of sorts that needs to be pulled/pushed out of slots on the crank. I use a piece of flat steel, sometimes a hooked pick works. Good luck with them.
Clip looks like this. As @scrapdaddy stated, you can push on the open ends with a flat piece of steel, or try to hook the closed end with some sort of pick and pull it. Patience...because you can quickly destroy the door card.
