SOLD 1972 FJ-40 No. California
roseville,ca
Year
1972
  1. 40 Series
Mileage
73000
Color
white
Listing this for a friend.
Description is as follows :
TOTALLY AWESOME 1972 FJ40
STARTING AT THE FRONT…...CUSTOM BUMPER, STAND UP 8000LB WARN WINCH
GM POWER STEERING BOX AND PUMP WITH ADVANCE ADAPTER MOUNTING PLATE, BRAIDED STEEL LINES AND STEERING SHAFT ADAPTER KIT. STEERING CORRECTION KIT.
4 INCH SPRING UNDER LIFT WITH GREASABLE SHACKLES FRONT AND REAR V-BOLT PROTECTOR PLATES
350 CHEVY V-8 FRESH LOW MILEAGE FULL REBUILD 30 OVER, 2 BOLT MAIN ARP STUD KIT, ARP HEAD AND ROD BOLTS, BALANCED FULL ASSEMBLY CENTERFORCE CLUTCH EDELBROCK RPM 202 ANGLE PLUG HEADS, ROLLER ROCKER, RPM MANIFOLD HOLLEY OFF ROAD CARBURETOR, HEI DISTRIBUTOR, BILLET PULLEYS
HEAVY DUTY DESERD 4 CORE RADIATOR. TOYOTA CORRECT FAN SHROUD AND FLEX FAN NO OVERHEATING PROBLEMS
FROM MARKS IN AUSTRALIA IS THE CHEVY TO LAND CRUISER BELL HOUSING ADAPTER KIT ALSO FROM MARKS IS THE LOW GEARED FULL SYNCRO 4 SPEED TRANSMISSION NO CUTTING TO INSTALL DIRECT BOLT IN REPLACES STOCK 4 SPEED
4 WHEEL DISC BRAKES, STOCK PARK BRAKE ON TRANSFER CASE, NEW TOYOTA DRIVE LINES WITH BIG HARDWARE 488 GEARS, ARB LOCKERS FRONT AND REAR
BLOCK HUGGER HEADERS, CUSTOM 2 INTO 1 EXHAUST WITH X PIPE
CUSTOM REAR COOLER CARRIER LEFT AND RIGHT ROOM FOR 35 INCH SPARE
EXCELLENT PAINT 15 YEARS OLD STORED AND COVERED
37” MTR TIRES ROCK SLIDERS CORNER PROTECTORS NO HIDDEN DENTS OR DAMAGE
SOFT TOP EXTRA HALF DOORS, CUSTOM BUILT LARGE DIAMETER, THICK WALL ROLL CAGE, POWDER COATED
FULLY RE-MANUFACTURED STOCK SEATS WITH HEADRESTS, POWDER COATED MOUNTS AND FRAMES THROUGHOUT
CONFER REAR SEAT WITH TOOLBOX
STOCK REAR HEATER ALL GAUGES WORK WITH ADAPTERS AND STOCK SENDERS IN CHEVY ENGINE
CUSTOM REAR BUMPER WITH HITCH AND CUSTOM TAIL LIGHTS
HAS NOT BEEN ROCK CRAWLED!
SMOG EXEMPT, RUNS STRONG NO ISSUES
Asking $27,000
Reasonable offers will be considered.
Vehicle is currently located in Granite bay, Ca. and has current registration and title.
Contact Trish for more info at
triciamsL5@gmail.com
Thanks.
Sent you a pm
