For Sale 1972 FJ-40 Landcruiser AKA Green Hornet in Wi
WI
1971 FJ-40 Landcruiser AKA Green Hornet in Wi
Here is the old link to the hornet when it went to TN. (NOTE SOME CHANGES HAVE BEEN MADE TO THE RIG)
https://forum.ih8mud.com/vehicles-trailers-sale-wanted/460476-1972-fj40-green-hornet-2.html
New Clist Ad
71 Toyota FJ40 Landcruiser
For sale is a 1971 Toyota FJ-40 Landcruiser, AKA the green hornet.... Clean and clear title. This rig spent most of its life in MN, and I brought it over to WI for a wheeler, but I have way too many irons in the fire. This cruiser is highly modified with some off road bells and whistles. The body is beat up, but the rust is very minimal. The frame is excellent with no rot or anything like that.
Turn key run and drive rig. I've done 55MPH comfortably, its not a race car.
Everything works the way it should. It has a spring over lift and a shackle reversal. FJ-55 Springs.
Email direct at jacobw_25 @ yahoo.com.
This was not built to be a high speed 80 mph daily driver, it is a rock crawler... It could be made into one with little work (gears ect). You probably could drive it home if you wanted, I would recommend that you trailer it.....
$3000 Takes it home
Highlights.
1F engine
GM HEI ignition ( Done properly so the cam gear does not get ate by the dist gear).
Regular Good battery
GM 1 wire Alternator
Saginaw power steering pump
IH Scout power steering box
Extended wheel base 103"
Disc brakes front and rear
Open front diff
Open rear diff.
4.11 gearing
GM SM465 transmission (rebuilt) , adapted to a 3 speed Toyota LC Tcase.
American autowire highway 15 wiring kit
33" tires on 15x10
10 gallon Fuel cell
Aftermarket gauges
LED rear tail lights
Black Bikini top
Steel Half doors
On board york air pump (needs to be hooked up, but is mounted to the engine).
Leather seats (from the Mid row section seats of a FJ-80)
Aftermarket speedo (speedo works and is accurate 40 mpvia, tac, oil, temp, volt
NOTE - WARN 8274 in pics is NOT included
NOTE - I have no hardtop anymore. I do have a set of rust side doors and the full fiberglass top piece that I will toss in.
:beer:
Email direct at jacobw_25 @ yahoo.com. please. Thanks
Again? I almost bought this last time when it was in TN. Great rig with a great history and story. It needs to go to another great Mudder!
Since its been in WI, I've drove it twice. Probably 60 miles on it since it left TN.
Currently it sits under my car port.
Two bad disks in my lower back and one in my neck that are not going to get any better are preventing me from using it to its fullest.
Hopefully it goes somewhere where someone will be able to use it and enjoy it.
I should just bring it back home... :-)
Jen would kill me.
Sure is good to see its still around.... Hopefully whoever purchases it keeps it close to home....
Shes seen some trails...
Black Hills and Colorado.... blast from the past.... :-) That F will run on its side..... Ive seen me do it.....
