1968 Hazard Flasher
Michigan
Has anyone found a replacement for the hazard flasher? It is located on the drivers side front of dash under the IP near the clutch pedal.
Mine doesn't flash, just illuminates the bulbs. I disassembled the unit, cleaned the points, it just lights an buzzes, no flashing.
I tried a turn signal flasher I had, it does flash but too rapidly, so I am going to get a heavy duty one and try that, assuming the bulb load is too high for this one.
SOR has a used one for $60, not ready to jump there.
Thanks
Last time I checked, Toyota still offered a solid state replacement. 12H04 suffix code iirc.
Thanks, looks like these are standard flashers, may try a HD one first.
The Toyota P/N 12H04 suffix code iirc, returns turn signal flasher, not hazard. Not sure if it would work as the number of bulbs for the turn are half of the hazard, I.E 3 ILO 6.
Bookmarked the sites if the HD doesn't work
Thanks
i offer the Correct TOYOTA Genuine Parts NipponDenso part #
i ALSO have a GENUINE NipponDenso Heavy DUTY Option Available too
65swb45, sorry. I thought the P/N would be sufficient.
You can fix that any time.😉 And FWIW, I wouldn’t be surprised if @ToyotaMatt hasnt already made up an adapter harness. As far as I’m concerned,The adapter harness is the only thing of value in Toyota’s 12H02/4 replacement.
Interesting your comments disappear when I log in.
I do understand as you are a retailer.
To set the record straight, the NAPA vendor did not state this was a direct replacement, they pointed out the terminals were at a different orientation. I decided to reconfigure the connector.
As far a longevity, I have used these flashers in other vehicles, some off road, no issues as the flasher is seldom used.
Regarding made in Taiwan, most of our micro chips are made there.
I do appreciate your thoughts.
