GM 1968 C10 stepside shortie build.
Had to make the rest of the bow ties match the one on the grille..
D
Safety first! Seat belts and door seals came in today.
D
Matchy matchy.. #PaintyMcHufferton
D
Got the box taken back apart so I can paint the crossmembers and patch some rust on the bedsides.
D
Only had to cut 2 out of 14 bolts to separate the box sides from the rear cross member and head... gate.. board? This is gonna make things more manageable.
D
Paint booth is too cold today so I guess I'm doing metal work on the bedsides.
D
D
Yaya, not yet. Just busted them out to measure where I had to notch the bed cross members.
D
X members were notched , the ends where the bedsides bolt on got sleeved and the rearmost cross member got wire wheeled after filling a couple holes.
D
Managed to get all of the bed cross members primed and painted, the rear one got painted green then patina'd. Primed and painted the rear frame cross member as well.
The ds bed mount that the front bed x member bolts to had the hole drilled super close to the edge so I added a little meat to it.
D
Got the first coat of paint on the front bed panel after getting it stripped and primed then called it a night.
D
Did a little stripe job on the rear cross member last night.
D
The rest of the stereo junk came in. Sound deadener, 2 6x9's, and a marine amp/sub unit.
D
Pre drilled, prepped and painted the 6x9 panels and sound deadened the back of the cab while I waited for the paint to dry.
D
Got the 6x9 panels, the speakers, and the sub/amp installed. Speaker wires are routed to the dash.
I'm doing a great job avoiding working on the bedsides, lol
D
Got the back of the cab painted green and the frame painted black today. #PaintyMcHufferton
D
