For Sale 1966 FJ45 $31000
Please follow the link for contact info. Thanks for looking!
1966 Toyota Landcruiser FJ45 LWB
Canadian funds?
you might want to add more verbiage to the listing. engine? running gear? brakes?
what work has been done to it? the windshield flap and running boards don't look quite right.
might be nice to get the pass door hinges the same body color, and install the missing screw in the windshield hinge.
is that bondo cracking on the passenger fender?
Canadian funds, located in Victoria BC.
The truck is all original with the exception of the engine which is a 77 2F. The windshield flap and running boards are OEM, though the PO sprayed box liner on them for some odd reason. Passenger fender has some damage after a run in with a high lift jack. It has been a daily driver for 4 years, with very little trouble.
Things I have replaced fixed after purchasing 5 years ago:
  • New upholstery
  • tires
  • wheels
  • turn indicators
  • all regular maintenance including fluids, filters, valves, timing, hoses, etc.
  • Rad and hoses
  • Dizzy - big cap from Astro Van
  • Aircraft style seat belts installed
  • gauge cluster rebuilt
  • knobs restored
  • oil pressure sender
  • Various electrical connections
  • Front end rebuild
  • brakes all around 2015
  • Clutch cylinder
  • Brake master cylinder
  • heater rebuild
  • installed windshield wipers, including motors
