For Sale 1964 FJ40 SOFTTOP PROJECT, Buckeye AZ
Buckeye, AZ
Year
1964
  1. 40 Series
Buckeye, Arizona 85396 United States
Outside Link
https://forum.ih8mud.com/threads/arizona-complete-1964-fj40-project-15000.1329339/
1964 FJ40 Soft Top can be a project of yours or we will build to your specifications.
This has clean body, pin hole corrosion in floor boards. Has been bead blasted and primed, but has some minor surface rust.
Frame is powder coated satin black and in great condition.
Conversion to running 2FE engine with new H5 tranny with split transfer case.
Axles rebuilt with front Disc, and full float rear.
All new brake system from pedal to pad.
60 series power steering with upgraded steering linkage.
New 2" lift leaf springs and shocks (OME).
16" Toyota rims with BFG tires
New custom harness for Cab and Rear (@Coolerman)
Toyota FST bows complete with FST doors. Original metal doors included.
OCD Beatle soft top in great condition minor mold spots on clear vinyl.
Can share more photos on request.
Worth noting the 16” wheels are from CityRacer.
Also worth noting the H55 is installed without a crossmember at this time.
The firewall has been modified for a vacuum brake booster as well.
This the same one that was for sale on the forum last year ? George built the axles ? New h55 and I forget the details about the motor but think it was a used not rebuilt 2F with a 3fe setup.
What are you asking for it ?
Never mind I see you have the link to the original add.
I got to go see this today. I am no expert, but it looks like pretty much everything is there. The frame and axles are awesome, especially that FF rear. Sure wish I could find one of those. :) No rust to speak of. No rat's nest of wires. The wire harness is all labeled. I bet there is more in parts than the seller is asking for it.
Adding some engine picks and the steering linkage in progress.
