1475mm Love
N43.875, W121.455
Website
www.instagram.com
Somewhere there was a post of fitting the Alu-Cab to a FrontRunner rack. The trouble is how the Alu-Cab attaches at the side rather than in the middle.
My solution was to swap out the 1255mm slats and front/rear combination pieces with 1475mm versions. It’s the perfect width for this application. Where the Alu-Cab mounts you need to use a long woodworking pipe clamp to compress in the side rails as it’s about 1/16” too narrow to get the screws in without the squeeze. You could alternatively mount the rails upside down but then you’d block under-rack mount for your $400 camp table. :)
The front combination rail needs to be mounted inverted as it would hit the Alu-Cab underside stiffeners. Also, the front two slats need some shimming to make for a level rack top. I used a double stack of Gr 8 fender washers. As discussed elsewhere, the 200 mounts don’t result in a flat rack top. This results in a side rail that is forced to bend and then an awning that doesn’t easily mount. With the washers it’s nearly perfect.
Am I glad I purchased the FR? I think I am. It’s been a hassle to sort out and I’m a bit frustrated by the mounts. But I really like versatility of the rack accessories and the light weight aluminum. And without the tent it was nearly silent on the 200.
And now I have a nearly complete 1255mm Slimline 2 that I can mount to the 100 with a few additional bits.
Anyone looking to put a FR on a 200 would be well advised to sort out the platform size first. FR can easily customize the rack package with available parts to your needs.
I didn’t like the Front Runner at all, I’m very happy I changed to a Rhino Rack. Details in my build thread, I will just say the multi piece design of the Front Runner is great for shipping but not so great for a flat platform rack.
The Slimlines really are awesome and they keep putting out more and more fun attachments. My favorite is the bottle opener!
That rack looks so weird with the side rails on it. I like it a lot without, but with it, especially on a stock truck, just looks like there's too much going on.
Yeah had to have the side rails for work stuff! It's my company vehicle but tons of people ask about it so it can't look too bad!
Sorry about that didn't realize it was yours! Your truck is one of my fav colors especially on the early LXs. If whoever buys it doesn't want the side bars I'm sure it's a matter of a few bolts then it's gone.
