Pulled the trigger on two new lathe chucks. The first upgrade is a 8" Bison 4 jaw scroll chuck with independent jaw fine adjustment. A back plate register was machined to match the chuck's register. One hour in the freezer (back plate) and she went together nicely.
A precision ground arbor was used to check TIR. Very pleased with .0002"
The second upgrade is a 5C scroll (with true-set) chuck and a 65PC collet set.
Same arbor was used to indicate the chuck. The last photo shows it in motion (40 RPM) with less than .0002 TRI. About a needles width of indicator. Gonna need to buy a .0001 indicator hehe
The lathe is also getting a new control system with auto shut off (hall sensor), braking,torque curve adjustment, variable speed control with RPM speed indicator momentary reversing switch etc. This will come in handy for single point threading without having to disengage the 1/2 nut for the entire threading operation.
