'14 Tacoma alignment issues
Salinas, CA
Mine pulls right 99% of the time. It is exhausting to drive. It also follows the crown left if there is enough of a crown, like in the passing lane.
I bought it in December. I am about ready to sell it.
I have had it aligned three times. I had the last alignment shop tweak things out of spec to make it pull less. I have also inflated the driver's side tires to about 5 PSI lower the ant passenger side.
It appears to have been crashed at some point based on poor body work. The dealer who sold it to me swore it was never in an accident. roll eyes.
On a whim, I measured the distance between the front and rear wheels. The passenger side is 3/4" longer than the drivers side. As far as I know, none of the shops checked this. Shouldn't it be square?
I suspect the rear axle was pushed forward in a crash on the driver's side. Would that make it difficult to align to drive straight?
Do you have a printout of the alignment? Did they measure SAI and IA?
I could not find a printout. I'll call one of the shops that I more or less trust and ask them about it.
I have owned about 15 cars and trucks. IF a the vehicle gives you three seconds before it is over the right white line lane marking, if you let go of the steering wheel that is dangerous. To some degree it has been an issue with a few of my cars but not most. In all cases I was able to make them drive straight. IMHO it should track straight with a centered steering wheel, on any reasonable crown. If my wrist gets sore from constantly steering left that is not OK. Unless it can be resolved I will sell it. Better to loose some money than have an accident.
a vehicle that's "properly" aligned should fight right lane crown. generally, a bit weaker caster on the left side. this is a common alignment spec on domestic vehicles. obviously that will effect left crown driving. finding a good alignment tech is important.
