Yeah I really should, and sliders, and and andI think it's just four bolts but I could be wrong. I'd take this opportunity to go ahead and upgrade to an aftermarket skid plate lol.
Good advice. My new to me GX only had 2 of the 4 screws. And the oil change history was all oil changes prior to my first as it's new owner were at Lexus... I bought replacement bolts online, but stainless would be better.skid plate bolts are M8-1.25x20mm. Do your future self a favor and buy some stainless bolts, the oem ones suck
Thanks gents, I’ll grab a box...need to have some spares laying around for putting my 55 back together anyways.Good advice. My new to me GX only had 2 of the 4 screws. And the oil change history was all oil changes prior to my first as it's new owner were at Lexus... I bought replacement bolts online, but stainless would be better.
Update, went to the nearest dealer for airbag recall, turns out they did a fuel pump too...I paid for a fresh sock on the new pump as it wasn’t covered on recall. All good.
But then the GX left on a tow truck last week.
Wife heard something clunk, then it got worse. She drove straight home & parked it for me to look at...ugh.
Near as I could see there were no threads left in that hole, same shop did brakes as when I had the splash pan fall off after oil change, not happy.
They are making it right, sent the wheel for repair too I’m told, will update when I get it back.
^ ThisHow TF do you "repair" an aluminum wheel like that??
Rear hatch won’t open,Rear hatch handle is getting sticky in the (mild) winter here, short of pulling the whole door apart is there a special spot to spray some lube?
is not amused…I wonder if I can get at it without pulling the interior part. Ugh.It's not that hard to pull the panels off the rear barn door. Note (if I remember correctly) that you'll need to remove the top window frame plastic first, then the bottom half. There's a screw inside the grab handle inside, center, bottom of the rear window.Rear hatch won’t open,is not amused…I wonder if I can get at it without pulling the interior part. Ugh.
TY for thatIt's not that hard to pull the panels off the rear barn door. Note (if I remember correctly) that you'll need to remove the top window frame plastic first, then the bottom half. There's a screw inside the grab handle inside, center, bottom of the rear window.
Then check to see if there are any issues with the cable length not pulling far enough to pull the latch.
kid hauler, what about ARB skids? They'll go further back than just the one RCI skid, costs the same as the one RCI skid and will protect better than OEM. They're heavier duty than stock but not as heavy duty as RCI and the like.I agree on budbuilt. Have one on both of my 460’s and it makes oil changes so much easier.Budbuilt has oil filter access door designed for 1UR-FE.. in addition the stock center jack point on skid is also on the Budbuilt.
With what the exchange rate is right now with Canada, it's only $483.5 USD (as of 06 Mar 2025)! (plus shipping)Any comments on the RCI skid plate? I need something badly, destroyed the stock splash pan
Ok neato!Budbuilt has oil filter access door designed for 1UR-FE.. in addition the stock center jack point on skid is also on the Budbuilt.
