To answer an earlier question, the original 93-97 alternators and mountings are all the same.
Just an update to those that were interested in this conversion. First, I had informed some people that wanted to buy a bracket with the electrical connector that the electrical connectors may not be available as I had purchased the US supply of them and there were only so many. It turns out after a conversation with CDan that I bought the current US supply. Dan said there were more connectors in the pipeline from Japan so more will be available in the future. He was shipping across the country to me today so those that are waiting for their orders can gauge from that.
Oh, now I see where all those connectors were going!
-o-
out of five.
We need some pictorial representation here man!
An update based on my recent install.
Hope you upgraded the OEM power main output wire and the engine to ground wire to a heavier gauge as I did on mine because if not, you will waste a lot of amps from your new Tundra alt to heating them![]()
Has anyone on here actually run the outbackoffroad gear alternator? That's a cool bracket and definitely an option. However, something that is a complete bolt in wouldn't be a bad thing in my mind. Good idea on upping the wire size. I'm about to up the following three to 4 gauge: battery + to alternator + ; battery - to chassis ground ; and block ground to battery ground.
I spoke with my father who is in the alternator business, and he thinks even the stock alternator could be a little limited by the small gauge wire. The only thing I can't decide is if I want to mess with the strange fusible links.
Good point on the use of an actual Toyota part, that would sway me back to using this bracket and the Tundra alt. Good to see others agree on the thin stock wiring and that others have actually replaced it.
Oh, but if you replace the positive wires, make sure to do the grounds too. The current flows in a loop, so you will gain nothing if you have 4 gauge power, and 8 gauge grounds.
There is now another option for those considering this modification. When I spoke to Cruiserdan last week he said that Toyota just came out with a reman 150 amp alternator. He said pricing is about $100.00 more for the 150 amp reman as opposed to the stock 80 amp reman iirc.
Bill
