12Volt Alt on 24Volt System
Sure thing - Plan is to fit a 12V HJ61 alternator onto the 12HT in my 24V HJ60 rig.
FJota - where did you put your third battery?
Mine is a right hand drive so it will be different then yours. Hope this helps.
If you use a 24V -> 12V converter to charge the 12V battery, how does it know when to stop charging? Does it have a voltage reg built in? I worry that it would be easy to overcharge the battery. Just curious.
GG
GG
Most are constant voltage at 13.8V. Not the fastest charge but it won't overcharge at that value.
I had wondered about that. Was in at the local sparky shop just a bit ago but forgot to ask.
So, there's no problem wiring my voltage reducer direct to a deep cell battery and then run my accessories off the deep cell via a fuse block?
IIRC greg_b talked to the Solar Converter guys and they told him their 24/12V converter was ideal for this application (charging a 12V battery). No need for a charge regulator.
I don't recall the particulars, so hopefully Greg'll see this and post up.
Wouldn't want to run my 12V winch off that circuit.
GG
The 12 V alt was more work, but I don't have to worry about what I run on it.
