In my opinion 12volt alternator is the only right way to power your 12 volt stuff.
Before I had overloaded two or three 24-12volt converters so I had pretty bad experians with that.
I used the 12 volt to power the radio, amplifier, 12 volt cooler, all extra lights (backup, spotlights and a searchllight), mobile phone, VHF radio, water pump for a water to air intercooler, all the original interior lights, the headlights and the heated seats.
The best part was that I could power the radio ond lights witout worries about draining the start power. I used a 75 amp/hours deep cycle battery.
The alternator was a 80 amp Bosch. I installed it over the power steering pump, under the upper cooler hose and re routed the lower hose over the alternator.
I welded a extra pulley to the power steering pulley to make space for the extra belt.
Well some pics, I will try to answer any questions you might have.
Used silicon hoses to re route the cooler pipes.
I used this red battery for few days before I bought me a deep cycle battery.
The yellow light is the charge light for the 12 volts. I made me a 12volt acc, fully swithed on and park lamps power with 24 volt releys.
Used the fully switched on for the charge lamp, and the heated seats, the acc for the radio and the park lamps to power relays and switches for aux lights.
To make the original 24 volt interior lights 12 volt I opened the fuse box and soldired a new wire with 12 volts to the dome fuse instead of the 24 volts. Then just replaced the 24 volt lightbulps with 12 volt bulps.
Then I noticed that the clock in the dashboard was dead, so I had to connect it to another 24 volt power source since it is on the dome fuse with the lights. I also re wired the cigarette lighter with 12 power.
I did the same thing to the headlamp fuses, but for the high beams to work I needed to change the dimmer relay with a 12 volt one, I used a relay from a toyota corolla. And of course changed the bulps.
I dont have that cruser any more so I cant shoot better pics. Dont have any of the bracket I made to hold the alternator.
I had some troubles to stretch the belt, in the beginning. Finally I got bored of the noises from the belt and made me mechanism similar to the orginal toyota stuff. Used a long, treaded bolt to stretch the belt properly. I dont have any pics of that.
