12V to 24V bulb conversion chart
Lake Stevens, Washington
So I had a turn signal bulb go out on my BJ74, did my research here on MUD as well as online to no avail. Finally used the Toyota p/n someone had posted to try and order from the local stealer and they could get it in a week for $7 each.
When at Napa trying to find the correct one, I found this on my phone and was able to score what I needed. So hopefully this will save someone the hassles I went through. (yes I now have a copy saved to my phone) if you google.. 12V to 24V Bulb Conversion you will find this as well.
What I did was visually match up my bulb with the 12V version off the rack, then use this to have them order (or find in the back if it is stocked) the 24v version. I had to do it this way since the two bulbs I was replacing had no p/n markings on them at all.
