I'm adding a dual USB port with voltage reading to my 100 series. It will be mounted right near the radio and AC controls. I'm wondering where the best place to tap into is, without impacting the existing outlets or the cig lighter. For all intents and purposes of this application, the rig is stock. No dual batteries (yet), no fuse blocks (yet).
Would you run directly to the battery (seems like overkill but may provide the most accurate voltage reading)?
Tap into the kick panel or engine bay fuse box with an add a fuse?
Is there another accessory that you would recommend?
Thanks!
I tried using the search function but all of the results I found applied to replacing existing outlets or had to do with adding fuse blocks. @Trunk Monkey, your proving me wrong is welcomed.
-Ted
Thanks!
-Ted
job and really took more time to remove the panel and figure out how to get the cig lighter part OUT than anything.
Untitled
