12HT throttle shaft gasket / bushing
Colorado
I have a boost leak from my throttle shaft on my 12HT. Pulled the seal out and ordered a bunch of random ones from 123bearing and none of them fit. Surely someone has had this issue before and has a solution or source?
I’m going to try the plate from my spare motor, but am worried the seal is the same age and will have the same issue.
Swapped in my spare an no leak, but still an awful throttle related squeal I haven’t figured out that sure as hell sounds like air escaping somewhere. Will update if I find a fitting gasket.
Could you not track down a generic oil seal with the given measurements ?
I bought a handful and none worked.
