2H and 12H-T are 2 totally diferent beast ..
True, but he currently has a 2H and my reccomendation was to take the rig on a few trips fully loaded. To see exactly how much power etc he is going to need to do what he needs to do
True, but he currently has a 2H and my reccomendation was to take the rig on a few trips fully loaded. To see exactly how much power etc he is going to need to do what he needs to do![]()
hmmmmmm......
i am now thinking 12ht with intercool or 1hz with turbo and inter cool. i will look into the chevy duramax, but seem that there would be much modifications, has anyone done this?
If you're considering a 1HZ and turbocharging it, why not a 1HD-T?
Direct injection means faster starting and better fuel economy.
I think you are getting some great advice here.... good topic and sweet 47!
*if you click "edit" under your post, you can delete the photo as you like.
Hey, so what did you decide? The Duramax suggestion was really a joke (though it would be sweet).. I suspect it would be overly complicated IMHO. If you really wanted to put a diesel in there that would serve you well with that amount of weight: I would heavily consider a 12 valve Cummins with manual tranny... but there are compication with that as well, i.e. engine wieght, the manual tranny is kinda rough shifting (NV4500) some would say.
But, it can be done:
Cummins 6AT 3.4 in Toyota FJ55 - Cummins 4BT Forums
CIS Auto Web's Diesel Land Cruisers
same swap, just more pics....
i am almost decided on a 12ht with an inter cooler, with an inter cooler i maybe able to increase the boost power a bit in case i need it (any ideas on this?) and 5 speed transmission. one of the major draw is the easy bolt on to my cruiser. i am still trying to figure out how much modification on a 1hz or a 1hdt. i am also looking into lowering the weight of my cruiser...thanks![]()
12ht the go it looks as if designed specificatley for hj47 im in middle of my conversion 83 picked up donour vech. hj61 import for $8,000 and 167k use altnator, stater motor and mounts of h unless P.S2H and 12H-T are 2 totally diferent beast ..
