100 Technical Service Bulletins
Gleneagle, CO
Listed below are all the 100 series TSBs (technical service bulletins) listed on the US National Highway Transportation Safety Administration website as of August 2007 and as many foreign bulletins and recalls as I could find. This may not be all or even most of the bulletins issued by Toyota. If you are aware of any other bulletins let me know by PM and I'll add them.
Lexus LX470 TSBs are here - LX470 TSB Thread (note that the Lexus TSBs are not identical and may cover common equipment even if Toyota did not issue a bulletin for the LC so I recommend checking both threads when dealing with a problem)
I will add a "MUD Notes:" line with any info that will be useful for board members that is not contained in the summary. For an example see the "Reverse to Park/Neutral Chatter" near the bottom of the 1998 list. This info should be from an authoritative source (i.e. the TSB) and could include a link to a forum thread focused on the TSB. If you have information and/or experience with a particular TSB and are willing to help other board members then I will list you as a PM contact if you want.
I found this Edmunds.com article on TSBs very informative and recommend that you read it.
You, Your Vehicle and the Technical Service Bulletin (TSB) (from Edmunds.com)
Hope you find this useful. :)
Australian Safety Recalls (12/15/2009)
Toyota - Land Cruiser and Lexus470 - Front Disc Brake Rotor Retaining Bolt
Date: 01/03/2007 Campaign Number: 7531A Recall Market Coverage: Australia
Toyota Motor Corporation Australia Limited
Product Model: Land Cruiser 78, 79, 100 & 105 Series & Lexus LX470 Target Number: 137,479
Model Years From: 1997 to 2005
Serial Range: Land Cruiser 10#. Model Code FZJ105, HZJ105, UZJ100, HDJ100. Lexus LX470. Model Code UZJ100. Production period 30 September 1997 through 5 December 2005.
Consequences: In the worse case of all bolts on one side displacing, continuous vehicle operation may result in brake pull.
Defect Details: When vehicle is operated under severe conditions with repetitive high "G" brake application forward and backward, excessive forces applied to the brake rotor may loosen the front bake rotor bolt/s. If vehicle operation continues in this condition, one or more bolts may loosen further (unwind) and eventually rattle. Owners of affected vehicles will be contacted individually by letter. - Info at Product Recalls Australia
MUD Thread: Front Rotor bolt recall/replacement
Land Cruiser 100 and Lexus LX470—Dash Board Wire Harness Interference with Pedal Support
PRA number: 2008/10050 Date created: 26th May 2008
Defect Details:On certain Land Cruiser 100 and Lexus LX470 vehicles, there is a possibility that the dash board wire harness may be abnormally twisted changing its intended routing in the vehicle allowing contact with the unprotected edge of the pedal support bracket. If the vehicle is continuously driven on corrugated roads in this condition, the wire harness will rub against the pedal support bracket damaging the wire insulation cover resulting in a short circuit and blown fuse.
Recalls.gov.au - Wire Harness
Toyota—Land Cruiser and Lexus—Front Disc Brake Rotor Retaining Bolt
PRA number: 2007/9087 Date created: 1st March 2007
Product description:Land Cruiser 7#. Model Code FZJ78, FZJ79, HZJ78, HZJ79, HDJ78, HDJ79. Land Cruiser 10#. Model Code FZJ105, HZJ105, UZJ100, HDJ100. Lexus LX470. Model Code UZJ100. Production period 30 September 1997 through 5 December 2005.
Defect Details: When vehicle is operated under severe conditions with repetitive high "G" brake application forward and backward, excessive forces applied to the brake rotor may loosen the front brake rotor bolt/s. If vehicle operation continues in this condition, one or more bolts may loosen further (unwind) and eventually rattle.
recalls.gov.au - Rotor Bolt
Toyota—Land Cruiser 100 Series - Bullbar Brackets
PRA number: 2006/8591 Date created: 27th June 2006
Product description: Bullbar Mounting adapter brackets manufactured between December 1997 and October 2004.
Defect Details: During heavy winching operations, there is a possibility that the welds on the bullbar adapter mounting brackets which attach the bullbar to the vehicle may fracture and in the worst case allow the bullbar to become detached from the vehicle.
recalls.gov.au - Bullbar Brackets
Toyota—Lexus LX470, Toyota LandCruiser 100-105 - Spare Tire Cable
PRA number: 2002/5421 Date created: 12th June 2002 Campaign Number: 2506F.
Product description: Lexus LX470, Toyota Land Cruiser 100, 105 models produced from 7 January 1998 to 2 September 2001 , and HiLux 4WD models produced from 29 July 1997 to 2 December 2001.
Defect Details: When the above models are regularly driven on rough corrugated roads at high speeds for long distances, the spare wheel winch wire cable may become frayed due to road transmitted vibration acting on the under body mounted spare wheel.
recalls.gov.au - Spare tire cable
1998 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
ENGINE BANK 1 AND BANK 2 A/F AND 02 IDENTIFICATION
Service Bulletin : 03704 - SEP 03, 2004 NHTSA Item #: 10010021
EXHAUST BOOMING AT IDLE
Service Bulletin : 00304 - FEB 20, 2004 NHTSA Item #: 10006142
MUD Notes: Some 1998 – 2006 model year LC/LXs may exhibit exhaust booming after reaching operating temperature. To correct this there are various procedures for different vehicles. Installing a "Crossmember Damper Weight" (cast iron/rubber device on frame rail) or exhaust pipe dampers tuned to different frequencies. Credit to 100TD.
SPARE TIRE CARRIER OPERATION
Service Bulletin : PG00503 - AUG 19, 2003 NHTSA Item #: 10003563
CONTINUOUS ALARM NOISE FROM COMBINATION METER
Service Bulletin : EL00202 - FEB 22, 2002 NHTSA Item #: 629437
MUD Notes: Very loud warning buzzer from combination meter. Buzzer scares wife and costs $1150. :eek:
Parking Brake Buzzer
Serge troubleshoots Strange Sound and saves $1200
FRONT BRAKE VIBRATION
Service Bulletin : 757 - NOV 07, 2001 NHTSA Item #: 627469
Service Bulletin : BR0101 - NOV 02, 2001 NHTSA Item #: 627394
TOWING WIRE HARNESS CONVERTER REPLACEMENT
Service Bulletin : TC01030 - NOV 05, 2001 NHTSA Item #: 627356
SPECIAL SERVICE CAMPAIGN X03 TO REPLACE THE TRAILER TOWING WIRE HARNESS CONVERTER
Service Bulletin : TC99015 - JUN 18, 1999 NHTSA Item #: 608118
SHOULDER BELT ANCHOR TAPE SET
Service Bulletin : BO01901 - AUG 10, 2001 NHTSA Item #: 622728
MUD Notes: The solution is cleaning mentioned and then the application of "flourocarbon resin" tape to the Shoulder Anchor. Toyota part # 73205-48011 Tape Set, Shoulder Belt Anchor
MUD Thread: Safety belts not retracting properly (FAQ)
TRANSFER CASE BUZZ NOISE
Service Bulletin : NV00101 - JAN 25, 2001 NHTSA Item #: 616661
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:COLUMN SHIFT
MUD Notes : To address TCase buzz at lowspeed/moderate acceleration and highspeed/light acceleration Toyota modified the "Highspeed Output Gear", "Shift lever and Linkage" and the "Center differential case" (ie.. the whole Tcase). The fix to the problem if you have it is to R&R the entire works. 7.4 hrs. Covered under 6yr/60k powertrain warranty if there is a specific customer complaint. New t-cases installed from VIN JT3HT05J#Y0114609. If you have questions PM NMuzj100 or Zimm with your email address.
SEAT HEATER REPLACEMENT PROCEDURE
Service Bulletin : BO01600 - APR 28, 2000 NHTSA Item #: 613502
Service Bulletin : BO01600 - MAR 31, 2000 NHTSA Item #: 610966
PRODUCTION CHANGE TO REDUCE THE WIND NOISE FROM THE UPPER REAR CORNER OF THE FRONT PASSENGER SIDE WINDOW
Service Bulletin : 001704 - APR 17, 2000 NHTSA Item #: 610085
MOON ROOF WIND THROB NOISE
Service Bulletin : NV00200 - JAN 14, 2000 NHTSA Item #: 610064
Service Bulletin : NV00100 - JAN 07, 2000 NHTSA Item #: 610063
IMPROVED BLOWER MOTOR DURABILITY
Service Bulletin : AC00499 - OCT 15, 1999 NHTSA Item #: 6088651
REAR BRAKE SQUEAL NOISE
Service Bulletin : BR00599 - SEP 24, 1999 NHTSA Item #: 607904
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS
Summary: VEHICLES STARTING WITHIN VIN JT3HT05J*X0041300 MAY EXHIBIT REAR BRAKE SQUEAL NOISE.
REPAIR MANUAL CORRECTIONS
Service Bulletin : PG02099 - JUN 18, 1999 NHTSA Item #: 621990
Service Bulletin : PG01899 - MAY 14, 1999 NHTSA Item #: 621988
FRONT BRAKE PAD RATTLE NOISE
Service Bulletin : BR00399 - APR 16, 1999 NHTSA Item #: 605031
SCANTOOL IMMOBILIZER KEY CODE UTILITY
Service Bulletin : SS00199 - APR 09, 1999 NHTSA Item #: 605080
ADJUSTING PARKING BRAKE TO REDUCE RATTLE NOISE
Service Bulletin : BR00299 - APR 02, 1999 NHTSA Item #: 605038
MODIFIED REAR CUP HOLDER
Service Bulletin : BO00699 - MAR 26, 1999 NHTSA Item #: 604652
TOYOTA DINGHY TOWING GUIDE
Service Bulletin : AX00499 - MAR 19, 1999 NHTSA Item #: 604667
Component: EQUIPMENT:MECHANICAL:WRECKER AND WHEEL LIFT DEVICES
ABNORMAL NOISE FROM THE A/C EXPANSION VALVE
Service Bulletin : AC00199 - FEB 26, 1999 NHTSA Item #: 604643
Service Bulletin : 021699 - FEB 16, 1999 NHTSA Item #: 605168
Summary: ABNORMAL NOISE FROM THE A/C EXPANSION VALVE ON VEHICLES BUILT BETWEEN VINS JT3HT05J*X0024152 AND JT3HT05J*X0034757.
MUD Thread : AC Groan or Growl
REPAIR MANUAL CORRECTIONS ON POWER TILT / TELESCOPIC STEERING COLUMN
Service Bulletin : 020599 - FEB 05, 1999 NHTSA Item #: 605173
WOOD APPLIQUE KIT CHANGE
Service Bulletin : AX00498 - DEC 04, 1998 NHTSA Item #: 603186
SQUEAKING AND RATTLING NOISES BEING HEARD FROM THE GLOVE BOX AREA
Service Bulletin : NV00698 - SEP 18, 1998 NHTSA Item #: 603847
WIND NOISE SERVICE TIPS
Service Bulletin : 980827 - AUG 27, 1998 NHTSA Item #: 602536
BUZZ OR RATTLE NOISE IN THE LOWER FRONT SUSPENSION
Service Bulletin : 980825 - AUG 25, 1998 NHTSA Item #: 602513
Service Bulletin : SU00498 - AUG 21, 1998 NHTSA Item #: 602171
REPAIR PROCEDURES TO REDUCE WIND WHISTLE OR TURBULENCE NOISE FROM THE SIDE MARKER LAMP
Service Bulletin : NV00498 - AUG 14, 1998 NHTSA Item #: 602182
WIND NOISE COMING FROM THE ROOF RACK
Service Bulletin : NV00398 - JUN 26, 1998 NHTSA Item #: 601606
ATTACHING A WIRE HARNESS BRACKET TO TRAILER HITCH CROSS TUBE WITH SELF-TAPPING SCREWS REQUIRES LUBRICANT
Service Bulletin : 980603980603 - JUN 03, 1998 NHTSA Item #: 601328
TRAILER WIRE HARNESS INSTALLATION NOTE
Service Bulletin : AX00298 - MAY 29, 1998 NHTSA Item #: 601604
AUTOMATIC TRANSMISSIONS PRODUCE A CHATTER NOISE WHEN SHIFTED OUT OT REVERSE INTO EITHER NEUTRAL OR PARK
Service Bulletin # : TC00198 - FEB 13, 1998 NHTSA Item #: 600349
MUD Notes: Transmission serial #s 97H*-00001 -> 97K-99999. 2.3hrs. Only covered under 6/60 powertrain warranty. Repair involves installing a new check ball into the valve body of the transmission. If you have questions on this TSB PM NMuzj100 with your email address. Thanks to CPJONES1231.
FUSE INSTALLATION DURING PDS - LAND CRUISER
Service Bulletin : PG00198 - JAN 30, 1998 NHTSA Item #: 600196
A343F 1-2 AND 3-4 SHIFT IMPROVEMENT
Service Bulletin # : 980101 - JAN 01, 1998 NHTSA Item #: 602535
1999 Toyota LC UZJ100 US Model – NHTSA TSB listings (2/16/2006)
REPAIR MANUAL CORRECTION - POWER STEERING
Service Bulletin : 5167B - SEP 14, 2005 NHTSA Item #: 10017619
Component: STEERING:HYDRAULIC POWER ASSIST SYSTEM
Summary: REVISED INFORMATION REGARDING SEAT HEATER REPLACEMENT PROCEDURE.
CHANGE TO REDUCE WIND NOISE FROM UPPER REAR CORNER OF FRONT PASSENGER SIDE WINDOW
BLOWER MOTOR IMPROVED DURABILITY
Service Bulletin : AC00499 - OCT 15, 1999 NHTSA Item #: 610042
REAR BRAKE SQUEAL NOISE - VEHICLES STARTING WITHIN VIN JT3HT05J*X0041300
TOWING HITCH INSTALLATION INSTRUCTION AMENDMENT
Service Bulletin : AX00399 - MAR 12, 1999 NHTSA Item #: 605107
FRONT LICENSE PLATE INSTALLATION
Service Bulletin : PG00499 - MAR 05, 1999 NHTSA Item #: 605109
A/C EXPANSION VALVE ABNORMAL NOISE
Summary: CONCERNS WITH ABNORMAL NOISE FROM THE A/C EXPANSION VALVE ON VEHICLES BUILT BETWEEN VINS JT3HT05J*X0024152 AND JT3HT05J*X0034757.
ECU-B1 FUSE PRODUCTION CHANGE
Service Bulletin : EL00199 - FEB 19, 1999 NHTSA Item #: 604646
FUSE INSTALLATION INFORMATION ON VEHICLES STARTING WITH VIN JT3HT0525X0037670
Service Bulletin : PG01198 - DEC 04, 1998 NHTSA Item #: 603190
Service Bulletin : PG01098 - AUG 28, 1998 NHTSA Item #: 602174
  • Like
Reactions: KTP
2000,2001
2000 Toyota LC UZJ100 US Model – NHTSA TSB listings (2/16/2006)
Component: ELECTRICAL SYSTEM
MUD Notes : To address TCase buzz at lowspeed/moderate acceleration and highspeed/light acceleration Toyota modified the "Highspeed Output Gear", "Shift lever and Linkage" and the "Center differential case" (ie.. the whole Tcase). The fix to the problem if you have it is to R&R the entire works. 7.4 hrs. Covered under 6yr/60k powertrain warranty if there is a specific customer complaint. New t-cases installed from VIN JT3HT05J#Y0114609. If you have questions PM Zimm or NMuzj100 with your email address.
ELECTRICAL WIRING DIAGRAM AMENDMENT - ADDITION OF THE TRAILER CONVERTER CIRCUIT
Service Bulletin : EL00600 - APR 14, 2000 NHTSA Item #: 612540
TOWING CONVERTER SYSTEM - THIS CONVERTER SYSTEM IS NOT INTERCHANGEABLE WITH THE PREVIOUS TRAILER HARNESS KIT
Service Bulletin : AX00200 - MAR 31, 2000 NHTSA Item #: 610963
Summary: SOME VEHICLES STARTING WITH VIN JT3HT05J#Y0094690 EQUIPPED WITH A FACTORY INSTALLED TOWING CONVERTER SYSTEM WILL REQUIRE INSTALLATION OF A SUB-HARNESS FROM CONVERTER TO HITCH WHICH WILL BE AVAILABLE IN ALL PIO/DIO HITCH KITS. THIS CONVERTER SYSTEM IS NOT INTERCHANGEABLE WITH THE PREVIOUS TRAILER HARNESS KIT.
CLADDING AND BUMPER COLOR CODES
Service Bulletin : PA00200 - JAN 28, 2000 NHTSA Item #: 610066
2001 Toyota LC UZJ100 US Model – NHTSA TSB listings (2/16/2006)
REPAIR MANUAL CORRECTION - ENGINE DIAGNOSTICS - 00400-RM795-U1
Service Bulletin : 4625 - JUN 14, 2005 NHTSA Item #: 10015461
Component: ENGINE AND ENGINE COOLING:ENGINE
IMMOBILIZER KEY CODE RESET
Service Bulletin : 00301 - AUG 30, 2002 NHTSA Item #: 10000545
Component: EQUIPMENT:ELECTRICAL
IMMOBILIZER RESET FEATURE ALLOWS THE REGISTRATION OF A NEW MASTER KEY EVEN IF ALL ORIGINAL MASTER KEYS ARE LOST
Service Bulletin : SS00301 - AUG 30, 2002 NHTSA Item #: 634014
NAVIGATION SYSTEM SPECIFICATIONS
Service Bulletin : EL00602 - AUG 09, 2002 NHTSA Item #: 633875
Component: EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Service Bulletin : BO01901 -AUG 10, 2001 NHTSA Item #: 622728
ECU (ELECTRONIC CONTROL UNIT) FLASH REPROGRAMMING PROCESS
Service Bulletin : SS00201 - MAR 09, 2001 NHTSA Item #: 10003249
Component: ELECTRICAL SYSTEM:IGNITION:MODULE
SINGLE AND TWO-TONE PAINT SCHEMES
Service Bulletin : 356 - NOV 07, 2000 NHTSA Item #: 616070
INITIAL CALIBRATION OF REAR-VIEW MIRROR COMPASS IN THE DURING THE ROAD TEST SECTION OF PRE-DELIVERY SERVICE
Service Bulletin : PG01800 - SEP 01, 2000 NHTSA Item #: 614965
AUTOMATIC TRANSMISSION JUDDER - HDJ100
Toyota Europe Service Bulletin : CP-1018 (Revised) - JUN 2001
Component : Chassis/Powertrain
MUD Notes: Production change to Torque Converters from VIN JTEHC05J904005603 (JUN 5, 2001) for improved drivability/reduced judder under hard braking. Fix for older units is R&R Torque Converter and replace with an updated unit. For further info PM uHu.
TECHSTREAM ECU FLASH REPROGRAMMING PROCEDURE
Service Bulletin Num : 00207 - APR 26, 2007 NHTSA Item Number: 10022143
2002 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
Vehicle Recall - POSSIBLE FUEL LEAK 2002-2003 TOYOTA LAND CRUISER
Vehicle and Operator Services Agency (VOSA) - Department for Transportation - United Kingdom
Recall Date : 12/08/2003
Reference : R/2003/059 Manufacturer Ref : RR60539
Build Start - End Dates : 29/03/2002 - 22/03/2003
Vehicle Id Numbers : JTDBU2#J00001005 to JTDBU2#J00007122 Numbers Involved : 131
Description : The fuel injection system pulsation damper may have been damaged during manufacture. As a consequence it may leak and cause a fire hazard in the presence of a heat or ignition source.
Remedial Action : Fit a modified pulsation damper.
Recall details from VOSA-DOT
INSTRUMENTS - OIL PRESSURE GAUGE READS ABNORMALLY LOW
Service Bulletin: EL017-03 - DEC 03
MUD Notes:The bulletin was only issued for the Tundra and Sequoia with the 2UZ-FE but this seems to be a fairly common problem on MUD. Fixed by replacing the sending unit. Strange Oil Pressure - help? If anyone can get me a copy of the TSB sent me PM.
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
SPARE TIRE CARRIER OPERATION. VARIOUS MODLELS INCLUDING THE 2004 LANDCRUISER
Component: TIRES:TEMPORARY/EMERGENCY SPARE TIRE
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS: DISC
2003 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
ENGINE REPAIR MANUAL CORRECTION FOR 2003 TOYOTA LAND CRUISER.
Service Bulletin : 4424 - NOV 23, 2004 NHTSA Item #: 10016058
STEERING COLUMN NOISE
Service Bulletin : 00104 - JAN 07, 2004 NHTSA Item #: 10005840
SPARE TIRE CARRIER OPERATION. VARIOUS MODELS.
THROTTLE BODY MOTOR MAY MALFUNCTION
Service Bulletin : TC03015 - JUL 24, 2003 NHTSA Item #: 10003486
Component: VEHICLE SPEED CONTROL
Summary: THE THROTTLE BODY MOTOR MAY MALFUNCTION CAUSING THE MALFUNCTION INDICATOR LIGHT (MIL) TO ILLUMINATE ON THE DASH, AND THE ENGINE CONTROL MODULE (ECM) WILL STORE A TROUBLE CODE AND PLACE THE VEHICLE INTO A LIMP HOME MODE. TOYOTA WILL INITIATE SPECIAL SERVICE CAMPAIGN 30I TO INSPECT AND/OR REPLACE THE THROTTLE BODY.
DAYTIME RUNNING LIGHTS STAY ON WHEN TOWING A TRAILER
Service Bulletin : 00503 - APR 25, 2003 NHTSA Item #: 10001589
REPAIR MANUAL CORRECTION VOL II - 2003 LAND CRUISER BODY ELECTRICAL
Service Bulletin : 032503 - MAR 25, 2003 NHTSA Item #: 10001374
RESET PROCEDURE - SERVICE MAINTENANCE REMINDER LIGHT
Service Bulletin : 00203 - MAR 07, 2003 NHTSA Item #: 10001360
A750 TRANSMISSION SOLENOID IDENTIFICATION
Service Bulletin : 00103 - FEB 28, 2003 NHTSA Item #: 10001370
REPAIR MANUAL CORRECTION - ELECTRICAL WIRING DIAGRAM
Service Bulletin : 020603 - FEB 06, 2003 NHTSA Item #: 10001373
REVISED - DIAGNOSTIC TESTER IMMOBILIZER FUNCTIONS -
Service Bulletin : 00302 - DEC 11, 2002 NHTSA Item #: 10003608
SHORT PIN INSTALLATION DURING PREDELIVERY SERVICE
Service Bulletin : PG01902 - AUG 30, 2002 NHTSA Item #: 635851
2004 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
CUSTOMER SUPPORT PROGRAM - WARRANTY COVERAGE EXTENSION ON CERTAIN 2004 - EARLY 2005 MY 4RUNNER, LAND CRUISER AND SIENNA VEHICLES EQUIPPED WITH THE OPTIONAL REAR (BACK-UP) CAMERA. *NJ
Service Bulletin : 07015 - OCT 16, 2007 NHTSA Item Number : 10023698
REPAIR MANUAL CORRECTION - CHASSIS MAINTENANCE
Service Bulletin : 5246 - NOV 25, 2005 NHTSA Item #: 10018672
AUTOMATIC TRANSMISSION FLUID - REPAIR MANUAL CORRECTION
Service Bulletin : 5247B - NOV 25, 2005 NHTSA Item #: 10018677
DIAGNOSTIC TROUBLE CODE P2742 - MIL
Service Bulletin : 04805 - NOV 08, 2005 NHTSA Item #: 10018272
ECM CALIBRATION UPDATE - MIL ON DTC P0136 AND OR P0156
Service Bulletin : 04605 - OCT 05, 2005 NHTSA Item #: 10017641
REPAIR MANUAL CORRECTION - 04 LAND CRUISER NAVIGATION SYSTEM
Service Bulletin : 5142 - JUN 30, 2005 NHTSA Item #: 10015478
FIFTH GEAR SHUDDER
Service Bulletin : 00105 - JAN 28, 2005 NHTSA Item #: 10015192
SUNROOF WIND DEFLECTOR GASKET FIT
Service Bulletin : 00205 - JAN 25, 2005 NHTSA Item #: 10015193
POWER/RADIO WIRE HARNESS FOR REAR SEAT ENTERTAINMENT SYSTEM
Service Bulletin : 00504 - SEP 21, 2004 NHTSA Item #: 10010037
AUDIO SYSTEM MUTED AFTER ENDING BLUETOOTH WIRELESS PHONE CALL
Service Bulletin : 00304 - APR 22, 2004 NHTSA Item #: 10007105
ZERO POINT CALIBRATION
Service Bulletin # : 00104 - FEB 04, 2004 NHTSA Item #: 10006139
PRE-DELIVERY SERVICE (PDS)
Service Bulletin : 00503 - AUG 04, 2003 NHTSA Item #: 10010553
2005 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
REPAIR MANUAL CORRECTION FOR CHASSIS MAINTENANCE - 2004-2005 LAND CRUISER
Service Bulletin # : 5246 - NOV 25, 2005 NHTSA Item #: 10018672
MALFUNCTION INDICATOR LAMP ON DIAGNOSTIC TROUBLE CODE P2742
Service Bulletin # : 04805 - NOV 08, 2005 NHTSA Item #: 10018272
ECM CALIBRATION UPDATE: MIL ON DTC P0136 AND OR P0156
Service Bulletin # : 04605 - OCT 05, 2005 NHTSA Item #: 10017641
REPAIR MANUAL CORRECTION - DIAGNOSTICS - NAVIGATION SYSTEM - '05 LAND CRUISER
Service Bulletin # : 5143 - JUN 30, 2005 NHTSA Item #: 10015509
REPAIR MANUAL CORRECTION - UNDER HOOD WIRING
Service Bulletin # : 4527 - APR 12, 2005 NHTSA Item #: 10015662
FIFTH GEAR SHUDDER
Service Bulletin # : 00105 - JAN 28, 2005 NHTSA Item #: 10015192
Service Bulletin # : 00205 - JAN 25, 2005 NHTSA Item #: 10015193
ENTERING VIN DURING ECM (PCM) REPLACEMENT AND/OR DIAGNOSTIC TROUBLE CODE P0630
Service Bulletin # : 01204 - OCT 14, 2004 NHTSA Item #: 10010594
AUTOMATIC DOOR LOCK (ADL) FUNCTION
Service Bulletin # : 01004 - OCT 11, 2004 NHTSA Item #: 10010575
Service Bulletin # : 02904 - AUG 18, 2004 NHTSA Item #: 10009412
SCANTOOL SUPPORT FOR 2005 MODEL YEAR VEHICLES.
Service Bulletin # : 08102004 - AUG 10, 2004 NHTSA Item #: 10010435
Summary: NEW SCANTOOL SOFTWARE, PRODUCTION VERSION 11.0A, IS NOW AVAILABLE ON TIS.
REPAIR MANUAL CORRECTION FOR THE AUTOMATIC TRANSMISSION FLUID - 2004-2005 LAND CRUISER
Service Bulletin Num : 5247B - NOV 25, 2005 NHTSA Item Number: 10018677
2006 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
MALFUNCTION INDICATOR LAMP ON DIAGNOSTIC TROUBLE CODE P0171, P0174, P2195, OR P2197
Service Bulletin # : 05405 - NOV 16, 2005 NHTSA Item #: 10018273
SEAT BELT EXTENDER
Service Bulletin # : 01305 - NOV 03, 2005 NHTSA Item #: 10018292
DISMOUNTING TIRES WITH DIRECT SYSTEM PRESSURE SENSORS
Service Bulletin # : 01005 - SEP 26, 2005 NHTSA Item #: 10017615
TIRE PRESSURE WARNING SYSTEM DIAGNOSTIC TIPS
Service Bulletin Num : 00406 - NOV 28, 2006 NHTSA Item Number: 10021180
2007 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
TIRE PRESSURE WARNING VALVE/SENSOR ACTIVATION
Service Bulletin # : 07406 - AUG 08, 2006 NHTSA Item #: 10020682
Component: TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
SEAT BELT EXTENDER
Service Bulletin # : 00906 - MAR 28, 2006 NHTSA Item #: 10019786
REPAIR MANUAL SUPPLEMENT: VEHICLE PULLING TO ONE SIDE
Service Bulletin # : 00501 - NOV 16, 2001 NHTSA Item #: 10007586
Component: STEERING - TOYOTA/SCION ALL MODELS 2002 - 2007
NMuzj100,
You may be aware that I wanted to get TSBs in the FAQs a year ago but did not receive a favourable response at the time, and it has come up again recently and I said I was unable to compile at the moment but would try in a few months if I had the time. The listing you have here looks great. Can the TSB's be download to the MUD site so that they are a permenant fixture on MUDs server, so we can get them from MUD and not from elsewhere when their site or server changes hands, or they decide not to archive them etc?
Good stuff
100 TD
NM, very nice effort to benefit the community! Thanks for the work. That is great. I'll put it in the FAQ right away. (For those of you who don't know, NM has been by far the most helpful contributor the FAQ as far as ideas for threads to include etc... thanks!)
Anybody who has additional info on the actual TSBs info (Alldata etc) and on how they are acted on by Toy dealers, please add the info to this thread!
I don't quite get the meaning of your post e9999, if you have smething to say to me come out and say it. Why can't the info from alldata (as previously requested) or from this NHTSA site where ever it is, be put directly on MUD?
A good question.
Is there some kind of copyright restriction that prevents posting TSBs directly? (Or, maybe a server capacity restriction? TSBs are PDFs with pix etc...)
Alldata charges $ to provide the TSBs. I last subscribed to Alldatadiy.com in 2003 for $25/year, but am wondering if any relevant new TSBs have been released for 1999 LX - or maybe I missed something in 2003...it will cost me $25 to find out from Alldata, with a one year subscription. (NHTSA may list TSBs with titles/summary, but does not provide full detailed TSB content.)
one would assume that if you have to pay to access info, it can't be posted on a site like this one... copyrighted and all...
re: Alldata, I had a look and I didn't see Toyota listed for the TSB title listing.
other places where the actual info can be accessed for free? If you have the site addresses, please list them here.
Thank you NMuzj100 for taking the time to obtain this info and post it up for the rest of us!!! :beer: :beer: :beer:
All TSBs that come from Alldata are copyrighted and could not be directly posted. The original TSB is also probably a copyrighted product of Toyota and could not be posted in its entirety without permission.
I think the best way to handle these would be to add info to the above posts taken from the TSB that would help board members decide if their vehicle could be effected and if they need to get a copy of the TSB from their dealer. If you have a copy of any of these and are willing to share your insight on the problem let me know and I'll place your board name in the notes as a PM contact.
Alldata used to list the Toyota TSBs summaries but doesn't anymore. Alldata also was connected with the NHTSA for the dessimination of this info but no longer. It may be that Alldata was competing with TIS for the service information side of the business. Remember some dealers and mechanics think this information is what keeps people going to the dealer for service and so they guard it pretty closely.
And I posted a good article on TSBs at the top.
Interesting ...
I just attempted to search on a Toyota service campaign and this MUD thread was the top hit in Google.
"landcruiser service campaign" is what i typed in to make it come up. pretty kewl, lets not post any copywrited things here...since its a very popular link now and all.
Ive gone on TIS to get certain TSB printouts to bring to the dealer...they were more then surprised i had my hands on it. They were like, where did you get this you shouldnt have this blah blah blah...i was like i paid 10 dollars and downloaded a bunch of things off the same system your TECHs use, they were dumbfounded.
i think the way its posted is great it gives a good descrip and if the member is interested they can go forward and do more research on the troubled item; hey this might be a dumb request but can the lx 470 be included? i know they are almost exact and the 06 and newer are even more similar thanks i love this place i have gotten more info and resorces from this place when i had trouble with my 06 then from lexus
The problem with TSB lists is they can be for a problem, change is repair procedure if anyone ever has a problem, or just a correction in printed material. What is needed is a full list of TSB's that are about "problems" that need correction. This list tells you nothing, that's why they are free on the internet. They want you to pay to get the good info and with the LC/LX its a waste of time because there are few problems and the ones that do surface are covered in detail in posts on the forum. JMHO
I have been looking for the TSB concerning the amplifier replacement for my 2001, but it isn't shown on any list of TSB's (that I could find anyway). I was directed to TSB: AU001-01. Any help would be most helpful !
:cheers:
buzzer doesn't shut off older LX
It started with a buzzer when the e brake was on, eventually it became a buzzer on even while driving. Dealer wants $1700 to replace combination box. Save yourself a bundle by just blowing compressed air in the junction box next to fuse box lower left kick panel. Appears flakes of metal in manufacturing break off and short a connection, Mirrors may have problems from same reason.
staggering amount of insights... wo
