100 series New Clutch - Noise
Perth
Hi all,
I recently bought a 100 series (2003) manual that has recently had a new exedy clutch kit fitted. There is a slight chatter from the gearbox (noticeable in neutral with the clutch pedal out), and occasionally there is a slight chirp when I slightly depress the clutch pedal (goes away as soon as the pedal is significantly depressed) - this chirp is normally when everything is cold and goes away once it’s warmed up. What could these noises be?
Thanks in advance!
Was the throwout bearing replaced?
I would assume so as Exedy kits come with a new bearing. The invoice says that the flywheel was machined and ‘clutch replaced with customer supplied part (Exedy clutch). I’m just assuming that they would therefore replace it.
