100 Series Bolt-On Tire Carrier
Interested in a bolt on tire carrier
  • Yes
    Votes: 103 54.2%
  • No
    Votes: 5 2.6%
  • Possibly if under 1000.00
    Votes: 100 52.6%
  • DIY Kit
    Votes: 28 14.7%
  • Total voters
    190
Is it possible to purchase the dual or triple can holder (no hitch) as a standalone product? Essentially just a tray
I will be ordering from the laser cutter as soon as I send out invoices. With what I plan to stock in parts ans others interest I have enough to make an order.
I will be making these with the triangular shaped tire carrier. Allows the high lift to angle back and give more clearance for those with standard garage door heights. Plus a bit more strength to the carrier.
Jason
Anyone have an idea on how they are going to relocate their license plate to avoid a ticket? I am going to need to.
damn that looks great...nice and stout too
I also made an under cover wrap frame bracket. Super solid and no cutting through the bottom of the cover.
With one of my 1/2" spacers you can still run my tow point too.
Jason
TT
Jason
TT
that frame bracket is it going to be welded to the lower bar? Smart idea to stiffent it, this thing isn't going anywhere!
Not welded.. I tapped the arm to accept a bolt on one end and then it uses the factory frame capture nuts on the other.
J
is this pintle receiver on all 100s? Just need to cut out the bumper cover? have a 2000 LX for reference
AFAIK there are two different patterns. The 03-05 LX has the wider pattern and the pintle pattern found on every other 100 series is more square. Corrections welcome.
i have an 04 LX and it's wider
