1/2 shackle bolt question
Marietta, GA
Trying to replace my front shackles to get rid of PO gear- noticed the bolt is 1/2 inch versus 5/8 (stock diameter)- does this pose a safety risk? I am really trying to keep the bushings intact and not go down that road just yet... Any recommendations on where to find shackles with the 1/2 bolt?
1/2” bolts are for J**ps! There’s a reason Toyota uses larger bolts than Jppps. Be happy you discovered this now ...in your driveway. Spend the $$ to correct a PO mistake with hardware appropriate to a Landcruiser.
Either drill out the plates in your current setup to 15mm/ 5/8” or just buy some replacement shackles. I hear Marks Off Road has some really beefy ones. ;)
