For Sale 06 fleetwood neon popup, w-heat and MC rack
I have a 06 fleetwood neon pop-up trailer, I bought it from the widow of the original owner. He bought it and passed away after only using it a couple times. It sat in a garage for 3 years. Still had plastic on the cushions when I got it. I have used it a couple times a year. Its a one sided pop-up. low weight, under 1000 pounds! can be towed by almost any car or truck. The originate owner towed it with a honda element and had no issues.. I tow it with a wrangler. It is a "off-road" type trailer.. as in its heavier duty, but not for rock crawling behind a jeep unless some mods are done. It has propane heat,, yes HEAT! and I have reflex window insulation that I cut out to slip in between the screens and plastic in winter camping.. Heater doesn't work so hard then. I also insulated under the mattress and changed out the crappy rv thermostat to a digital thermostat. No rips or tears in the screens or canvas,, its near mint. Only issues are that it has a couple hail dents(small) in the roof from a storm I was bought in, it was packed up but still got a couple, none poked thru and it has an aluminum skin.. not the leaking problem kind. I mounted a bike rack on the a-frame and mount my ktm 450 there with no issues. My ktm LC4 was a bit heavy and would squat my jeep 2dr a bit in the back end. The front of the trailer is diamond plate and has a small dent where my foot peg bumped it when a strap came loose while tying down in a hurry at the hammer run while raining. If you've been to the hammer run you most likely saw it.. Has an awning off the back.. can put it on the side or get a second one.. has the mounting for it already there.
Asking $3800 OBO its in Jim Thorpe Pa, I travel all over Pa and Jersey for work so driving is not an issue.. if you need partial delivery we can always discuss that. Partial trades considered.. I could really use the money for medical bills(not bike related)
Email at cruiser1911 @ me. com-no spaces or PM me here..
oh,, and this picture is a bit old.. its snowing right now…
Will do,, I should have some out tonight as I think I have a few from my last camping trip. Can't snap any current ones as it's snowing again right now and was about 7 above zero outside.
