Fwd Fj40???
I'm pretty sure but others need to chime in on that. I have the aussie locker and i'm not exactly sure about the detroit. I do know the Detroit is much higher in price.
With the aussie you don't not need to take out the ring gear to put it in.
Do a search on aussie lockers in the 40 section. People love them.
The aussie locker and ezlocker replace the side gears, spider gears(all the gears in that center cage area) and that center pin collar. You also do not use the spider gear washers, but you must keep and use the washers for the side gears. I think there called thrust washers.
The easiest option would be to get new spider gears from someone. So many put in lockers and throw them out. You can change those with very minimal tools and knowledge. Next easiest is to pull the entire 3rd member, and swap in a new one (although it is heavy and the old pinion housing gasket usually takes a while to scrape off). Third easiest is an aussie locker.
For only the cost of shipping, I'm sure you could find some free spider gears if you have a hard time finding them in Italy.
If you have problems and don't mind $40-50 in shipping, I'll send you a set.
Awesome. Thanks a lot. I'll keep that in mind for sure.
Mike.
As long as were on the subject of lockers, I have a mall cruiser (95% in city) and I tore out the old rearend with a linked locker and threw A 72 rear end (its what was around). I occasionally do some really rough trails and would like a locker that handles both street(most importantly) and offroad nicely. Any ideas? I have heard mention of the arb air lockers aswell, anyone ever used one? Thanks:beer:
arb will work the same as on open diff on the road. you flip a switch to lock the diff
I got the locker and put it in yesterday. No complaints yet. I haven't had a chance to really test it out off road, but that'll happen soon enough.
Here are some pics of the old gears that were in there.
the pic of the dog was taken last night after Italy won the world cup of soccer. Now that was a crazy ass night...
You didn't need to take it all apart..
Do you know how to set up gears???
well, I did all the 'tests' it had me do at the end of the instructions, and the gap was within the tolerances noted. What else would I need to do? I drove it home from my buddy's house after we did it and everything seemed fine. What else would have to be set up?
mikedickbek said:
Well, I knew from the instructions that it didn't all have to come out. I just did that part for myself... learning a bit more about the truck.
What do you mean by setting up the gears?
Installing the Aussie EXACTLY as the instructions say and remembering to install the carrier and ring gear (the big round gear) back to the proper alignment. Even just a hair off from the former install can cause some big problems for you later.
When you put the carrier back in the third you shoudl have noticed a threaded nut thingie on either side of the bearing races on the carrier. That threaded portion matches the threads cut into the third and the bearing caps. You can see them in the open diff pic that you posted at the top of the page.
There needs to be an exactg backlash (measured in the thousandths) for the diff. If you are very far off, the third will slowly (or quickly) kill itself..
