Oil pan seal replacement
East Bay, CA
Hey,
I'm planning to replace my oil pan seal for the 3rd time on my '74 40 (1st 2 tries failed and oil kept leaking).
I know I've seen something about it in MUD but i can't find it.
any tips before I start?...what kind of sealant etc...
Thanks
Hey,
Any advice or tips for changing the oil pan gasket on my '74 40. I've done it twice already and still leaking.
I remember seeing something about that on MUD, but can't seem to find it.
THanks,
I'm pretty sure i posted this question earlier today, but can't find the thread!!
There's really only 2 "tricks" that I know of. First, as with all gaskets, make sure that it's completely dry and free of oil and debris. Second, with tins it's usually necessary to hammer down the sealing surface at the bolt holes, basically make it all flat and even across the entire surface. Check for any gouges from POs on the sealing surfaces as well.
Any specific sealant? or any at all...it seems I've been getting leaks at both curved parts of the gasket.
FSM specifies thread sealant, non-hardening on the bolts at the four corners. I put gasket sealant only on the engine block side. You almost have to hand form it into the curved ends. Also cork gaskets will compress, you may need to just put sealant on the four corner bolts and re-torque it. And you can easilu over-do the tightening of those bolts. I just did mine to a slight "squish" of the cork.
You are using the one-piece gasket?
GL
Ed
Yeah sure you could use it if you havn't been havin luck without it. I usually prefer to not use it unless necessary. Blue RTV silicone would work, or some of that hi-tack red crap might do also. Most importantly keep it all free of oil and bolt it up quick to keep the drips off the gasket and sealant.
Heh, using the Toyota one piece gasket...I've left the pan off overnight to get all the oil out (i think that was the problem before, never completely got the edges oil free)...we'll see....
Thanks for the help
well, spent the day cleaning the oil pan and engine to make sure I get a good seal and put everytning together.
I notice a strange thing, though. The front curved part of the oil pan is a couple of mm shorter than the engine block, so it kinda bites the edge of the gasket and pulls it out of place. The rear part fits perfectly. Had to loosen everything again and barely tighten the front in place....
anyone had a problem like that.
Hi,
I've always understood that it's best to use the OEM seals. That's the path that I'd follow.
The best sealant that I've EVER used is called Triple Bond. I got it at motorcycle shop and, when put on in a thin film, it'll seal up just about anything.
Are you sure it's the oil pan that's leaking? The pan gasket is a pretty straightforward job if you get rid of all old gasket material, so it's kinda' surprising to hear of a need for a second redo.
There are other places that leak and might make it seem like the pan.
One troublesome possibility is the oil gallery freeze plug at the rear of the block inside the bellhousing. Same area has the rear main seal. Another is the timing cover et al, and another sneaky one is the fuel pump. Oil can come down from the valve cover, the side cover, the distributor, or the oil filter and it's mount. All of them can sometimes appear to be pan gasket leaks.
thanks for the replies...
Figured it out...for some reason the oil pan is a couple of mm shorter than the engine block (!!!!) and it's pinching the gasket out of place when tightened too far. I've redone it to just about snug and gonna wait a couple of days and then fill her up with oil and see what happens.
Also leaking gas into to crankcase, probably from faulty fuel pump, so that's also making the oil thin and messing up the sealant.
Will see what happens when I fill her up!
