Going to look at possible 1st Fj40
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Ok, making my first trip on sunday to go and look at what might be my first FJ40.
1976 4spd Had a frame off sometime in the past (within 10,000 mi, but not sure how many years) -has some surface rust on the body but frame is supposed to be good.
What are the biggest things I should look for/feel for when looking/driving it?
The current owner is selling because he doesn't use it and wants someone to be able to have fun with it. -I plan on doing that.
Heres what I know
81,000 Miles
New brakes last year
tub has little to no rust
all switches and gauges work
clutch and slave replaced last year
fuel tank refurbished last year
good tires
Checkerplate rear corners
ambulance style doors (I believe)
Aluminum front bumper
no winch
Hard top
paint looks good
heat works
I'll be taking and posting pictures after I see it... don't worry!!
I think the asking price is pretty fair, compared to prices I have seen around, but I'll let you guys decide that. (after I post the pictures)
Any info would be usefull, thanks
I swear this thread comes up at least once a week :rolleyes: . Isn't it in the FAQ section yet for hell's sake? :D
I wish you luck on your first 40 :D . Sounds like a pretty nice one. Look for the obvious: rust, cracks, paint, bondo, panels hiding stuff, frame, wiring, check that everything turns on, maybe see if there's sut in the tail pipe, etc...
Go with gut feeling. Good luck.
:beer:
"Checkerplate rear corners" are the aftermarket aluminum quarter panels that are very often used to cover rusted steel original quarter panels.
"Very little rust" means different things to different people, but it ALWAYS means that rust is present. "Surface rust" is that rust which has not quite eaten all the way through a panel, or that on a panel which is so close to other parts or which cover an area so dark that it cannot be determined easily that there is in fact a through hole.
Canadians apparently have different definitions for the terms used to described oxidation of metal. So many, in fact, that it seems sometimes that a national aversion to the use of the word "rust" may prevail. This could be a cultural feature worthy of anthropological study.
diamond plate corners on a truck that has no/little rust?
red flag....way up.
take a magnet and some TP(don't want to scratch anything...) and crawl under it.
all switches and gauges work?
i would hope so, there isn't that many of either of.
we need pics to lead you better:flipoff2:
Here are a few pics I have that I have been sent - Not sure how recent they are. I believe that the checkerplate corners were only on there for the "cool factor" apparently the body under it is perfect, but I will be looking closely there.
Thanks for the tip about the magnet, that is a good one.
The vehicle will have been driven for about an hour before I get to see it (he is meeting me part way to shorten my trip) Is there anything that I would miss from that - other than the possiblity of some smoke @ cold startup?
I promise you, there will be rust lurking under the diamond plate. Still though, it looks like a nice truck. Spend at least an hour looking for frame rust. Look near the spring perches and shock mounts. Look at the spring packs for rusted and cracked leafs. If you can't quite tell, assume it's rusty.
That front bumper is pretty ugly-get the story on that!
If you have smog laws in your area, make sure all the smog stuff is there. Here in the PRK, the smog stuff has to be there, but it doesn't actually have to work. You just need to pass the tail pipe test.
I don't believe the 81k miles either. Unless the seller has bullet proof documentation, assume that it's 181,000. If that's the case the clutch replacement makes more sense. At 81k, it should be nearly new mechanically.
checking over it with a hot engine is better then looking over one that has just been driven around the block. smoke at cold start is'nt too much of a concern, and a little on a hot start is nothing to sweat either. all the fluids will be hot, so any nasty leaks will be in full effect. you can even sniff over the engine for any wiffs of coolant.
although it's pretty useless, take a look at the OP gauge as soon as he rolls up, to see how far down it drops at idle with hot oil.
yeap, given the choice of looking over one that just sat for two weeks, or one that just ran an hour and a half, i'd take the hot one.
Nobody puts that much diamond plate on a "rust free" Cruiser, unless they're hiding sumthin'. As mentioned that @&@&@&@& aluminum bull bar has got to go and the engine compartment is sketchy to me, not very straight for a recent frame off. Whatever he's asking, cut it in half.....
if it's a Canadian cruiser for sure theres rust under that checkerplate . what are they asking around 5,000 Canadian . you want to see rust on a canadian cruiser check out my rig follow the link in my signature below all the pics of the rig when it was blue where taken right up until i decided to take it apart , didn't look like there was rust , until i took it apart there was nothing left , there is a pic on about page 7 of all the rust , be careful !
p.s. that big piece is just a chunk of fiberglass
I'd have to suppose that anybody who added that stuff for the cool factor would still feel a little bit bad about making huge holes for the lights they added in back. I also see that the sill has been replaced since it was repainted. Which if it was rust free, I wonder why? I'd worry about that tub. Did they paint over the license plate assy?
"I believe that the checkerplate corners were only on there for the "cool factor" apparently the body under it is perfect, but I will be looking closely there"
Hope you know what you're looking at. Even if the panels under that aluminum WAS perfect when the stuff was added, which is doubtful, it isn't 'perfect' anymore.
That covering provides a place for moisture to enter between it and the truck body and stay, rusting it under the cover.
You're putting yourself in line for a lot of work/trouble by believing what you say you do.
"Cool factor" Bwa-HA!! What's cool about looking like a 3rd world Jitney driver?
MrMoMo said:
tub has little to no rust- that you can see, thanks to that aluminum covering it all..
Checkerplate rear corners.....oh and the rest of the sides of the truck that were rotted out, mudded over, then covered with this awsome aluminum....
proceed with caution.
There are a lot of nice trucks out there...I have a hard time thinking that this is one...
Cool factor. Those tail lights? :confused: :rolleyes: :shaking head:
Dude, are there no other ones in your area to look at? I'd just pass on this one, look for something a little more original (signals, bumper, tail lights, without DP everywhere. I'm just afraid that after you get it you'll be thinking twice and wishing you held out for a different one. Who knows though, if you really dig it, then go for it. IMO you'll find more enjoyment out of one that you have peace of mind knowing that things are as they were meant to be on your truck and not all hacked with by some PO.
My first one had DP corners and under the doors and this @&@&@&@&ty DP tailgate with a gate handle, oh and stinkin trailer lights for brake lights and a pretty nasty wiring rat's nest from one end to the other. Other than that it was mostly original. But I didn't know any better when I bought it and I wished that I did know better. I would have spent my money elsewhere.
Just do what feels right to you. Good luck.
If you look at the frame rails I would dout that this rig has had a "frame off". I would think the finish would last a lot longer than 10,000 miles.
..So you want to buy a cruiser...
This is alway's a good read. Lots to refer back to, and a good baseline for the new cruiser owner.
www.birfield.com/modules.php?name=TLCFAQ&p=/~ramullen/FAQ/TEXT/00-01.html
Here's a series of pages that outlines commen issues and ends with a reasonably complete checklist. Read section 20.0 to 20.13:
www.birfield.com/modules.php?name=TLCFAQ&p=/~ramullen/FAQ/TEXT/20-00.html
These issues mentioned are by no means exhaustive, but will at least give you a good baseline to compare the mechanical/rust merits of different trucks, and will prevent you from missing 'trouble' areas until you become more familiar with cruisers.
I've been told my many an 'old-timer', and firmly believe, that paying a trusted shop (that knows cruisers, or at least 4X4's in general) for an hour or two of labour to give the truck a mechanical 'once-over' is the best money you can spend. Paying $100 to find out a $5000 truck needs $6000 of work to get it safe/roadworthy and walking away from the deal is better than paying too much for a piece of junk. A truck with lots of mechanical/rust issues may still be good for a project, AS LONG AS THE PRICE REFLECTS THIS. If the same $5000 truck turns out to be a 'cream-puff', you'll know it right away, and will be able to put down a deposit before other cruiser-head catch wind of the deal.
happy cruiser searching,
Cheers,
Steve
