- Joined
- Apr 24, 2003
- Threads
- 208
- Messages
- 2,210
as the title says, do it every so often... especially if you have worked on it recently. that is all
ohh and for those that haven't experienced a drive shaft coming off the diff end at, oh say 60 miles an hour... don't try it. felt like i had a busted pinion bearing, so as i came off the gas, there was a loud bang/ thump followed by a loss in drive to the wheels. thankfully the shaft didn't separate at the spline, and i went back in front wheel drive and found all my nuts/ bolts with a torch. no damage that i've found yet.... what should i check, apart from the jocks :whoops:
yeah, when i replaced that uni joint 4 weeks ago i should have tightened them
