- Joined
- Jun 11, 2003
- Threads
- 170
- Messages
- 711
Thank you the members of this forum for your writeups and recomendations. I just replaces the PHH and it certainly lived up to its name. My truck now has about 91K on it and after reading the stories I thought it was time. I started by flushing the cooling system with a prestone flush kit. Then I removed the freeze plug right above the block drain and installed my engine block heater sourced through CDan from Canada. I was able to remove the freeze plug by drilling a 3/16 inch hole in it with a long drill bit extension and then using a punch with a long extension and a few taps to get it through the drilled hole. This knocked the freeze plug free and I then used needle nose vise grips to remove the plug. It is possible...thanks Robbie! After this I removed the top heater hose and loosened the bolt for the tube to the PHH. With the left front wheel and wheel well skirts still removed I located the little damn bugger and spent some time figuring out how to remove the oem clamps. I ended up tapping the cotter pin in the front clamp enough to be able to get a grip on it and bend it with some vise grip to remove it. The rear one was a real pain though and I ended up using a small cat's claw nail remove to pull on the top part of the spring tension clamp. This rotated the clamp to a position that I could remove it with vise grips. I cut the hose off with a sharp razor and then rotated the tube away from the block nipple. This provided enough room to slide the new blue/red silicone hose over the tube. I then slid the constant tension hose clamps over the tube and replaced the top bolt to realign the tube with the block nipple. Then I slid the hose over the nipple. These were suggestions by someone on the PHH writeup on Slee's Website...Thanks. I did not have to remove or lossen the top bolt for the tube which I see no way of doing anyway. I messed with this bolt for an hour before trying the other approach and I have those new gear wrenches that some others suggested. I have included some pictures of the procedure. I am now going to refill my cooling system and hope everything holds tight. Cheers.
J/K
