Spare Tire Lift???
Jefferson
I currently have my spare in the truck and have removed the spare carrier from under the truck. I need all the space I can get for an upcoming move. If this will work I will likely leave it as a permanent arrangement until I can afford a new rear bumper.
So the question is, will it work?
Rogue,
That should work OK for tyre diameters up to 33". Not sure about larger. John Holmaas did something similar and posted pics. There is a lot of verticle room under the cargo floor.
Let me know and I'll try to dig up links to his mods.
-B-
Rick,
Rogue removed the carrier from under the truck and he puts his spare in the cargo area for clearance when wheeling. Now he needs the cargo space for a move. His plans are to put it back under the truck but also to improve clearance by raising the spare the maximum amount.
-B-
Beo,
I think I have devised a way to raise the tire sufficiently. It looks as though it must go at least 4" and no more than around 5" up. What I worry about is how high the tire lowering doohicky will be once I relocate it. Any pictures of Holmaas' setup would likely help immensely. I already searched lcool and couldn't find anything there. Thanks.
Rogue,
Not much help but this is the only image I have.
-B-
That is perfect Beo. Tonight when I realized the amount of work need to fab up the brackets I imagined something like this. Now I just need to figure out exactly how high I can go with it.
Thanks!!!
I already have the nuts (I hope Junk doesn't read this). Yesterday I tried stacking 8 high and it was just a little too high to reach the lowering thingy. Today I will be trying 6. BTW the nuts are about 3/8" thick each so this should provide an adequate lift.
No comment on the # of nuts Rogue :D 0 but yeah dude the pipe would be mucho easier. Of course if you had Christo's bumper you wouldn't need to worry 'bout it. :D I don't think that with Holmaas's design you need to worry about the lowering mechanism at all. Should still be reachable.
It ended up looking just like the picture of Holmaas' setup. The bottom of the tire is at the same level as the recently re-installed reciever.
Junk,
I'd really like one of Christo's rear bumpers, but I am a bit short on cash and have bad credit. Want to give me some cash? :tear:
I would like to mimic this setup as it would be nice to have the extra clearance all the time. When you complete it, can you please post the lenght of bolts, thread, and number of nuts you ended up using? Also, if you can say if it created any rattles. I looked under the truck when I bought it because I couldn't believe it hung that low, and for the life of me cannot figure out why toyota put it down there (I am guessing crash performance).
Thanks
Hey Pimp,
How about adding a pic or two of your mod so this can be added to the FAQ's? I'm putting you to work dude :D
Hey Junk,
Here's a pic Rogue had posted of his lifted in another thread -
Tucker
This looks like a good and easy idea.
But I have a question. When you do this mod, can you still lower the tire with the handcrank in the original fashion?
Are there any downsides to this mod? Does it work with 285/75 tires?
Jared
[quote author=sjpitts link=board=2;threadid=1921;start=msg129631#msg129631 date=1080679374]
Jared
[/quote]
1. Works with handcrank as long as you don't try to raise it too high, you'll see what I mean when you do the mod.
2. No downsides that I've found.
3. Yes, works with 285/75 as well as 305/70
[quote author=tucker74 link=board=2;threadid=1921;start=msg129615#msg129615 date=1080678571]
[/quote]
As you can see in the picture, the hardware is rusting and it is getting worse pretty quick. I think I will be looking for another way this summer.
