I recently did 4-wheel discs on my 71 FJ40. Used JTO - lousy service. Front bracket not ideal. I'll probably rebuild the front in the future using the mini-truck buildout.
Am having to double-pump the brakes episodically to keep the pedal from depressing too far. No fluid leaks. Bled the lines well. Stops well (and straight for a change) otherwise. No problems with rear-lockup.
Using the stock master with assist. Didn't have that problem with the drums (lots of other problems like leaks, angled stops, etc).
Do I need to rebuild/ replace the master? Is the OEM adequate for 4-wheel discs?
