I've decided that I am going to piece together the parts to swap in a Ford V8 sometime in the next 2-4 years, I know Chevy 350 would probably be the easiest since it has been done several times, but I know Ford engines better and can get either of those 3 engines for cheap.
The Marks Adapter for the Ford to the A440 is the same for all, I have to beef up the axles (portals probably), VB job and possible rebuild of the A440, and make up throttle linkages and motor mounts.
Price and trouble of the swap seems about the same, but I cant decide if the 351 is enough, or if the 460 is too much, and pretty much just want thoughts on which I should head towords.
5.29s and longs/chromoly OR Volvo portals w/5.99s
Orion (if it comes out) OR lower t-case gears
38-40" tires
DD, but gas doesn't matter THAT much
38-40" tires
