Front Axel job due?
Twin Cities
Website
www.myspace.com
Driver side front, Back and Passenger side front:
Yep-It's time, classic symptoms.
It's a rite of passage....
No takers in the Twin Cities, anyway. :D
Check the club areas, you're more likely to find locals that way.
-Spike
So, how far you think I can go before it's necessary to do this? I've got a road trip to do this coming weekend to the northwoods of WI. Trip will probably be about 750 miles total. I greased them up about 4000 miles ago and had the diff fluid changed about 6000 miles ago. No clicking or strange noises yet, should I check other things?
Thanks
That diff fluid you replaced is leaking past the seal in the axle and turning the grease in the birf into soup, thin enough that it can leak out like you're seeing. It's not bad yet, when the seal is totally gone you'll get a nice spray pattern as the wheel flings grease all over the place.
Check the fluid in the diff (unscrew fill bolt, stick finger in, if you can feel fluid you're ok) and check the grease in the knuckles. If those are fine, you should be good to go on your trip. Add the axle job into your list of things to do before winter.
It shouldn't take more than a day to replace both axle seals and their oil seals if the person doing it knows what he's doing. 750 miles is a pretty long trip and if your oil seals give way on that trip the grease and diff fluid will flow like thick liquid. The cost of potential damage is considerable.
I suggest you get the parts and get the job done before the trip.
Kalawang
I agree with Kalawang.
Taking a trip under these conditions could potentially be very expensive.
Might as well get it done now.
Regards
Alvaro
I would do the work now vs. later. The gear oil is also thinning the grease on your birfields. Those are not cheap to replace...
An ounce of prevention vs. a pound of cure.
Spendy job
Well, I've called around town for estimates - not that this is any new info for people, just reinforces to do the job yourself (if you've got time, tools and the skills)
Myron's (local shop) - 1.8 hours for hub seal, 3.6 hours axle seal, they're not sure if that's per side or for both as they've never done one... (well, neither have I though) $86/hour
Metric shop - Had no idea how long it would take so couldn't give me an estimate... (I don't know how long it'll take me either) $95/hour
Toyota of Inver Grove Heights - 10 hours labor, $80 parts @ $112/hour thats $1,200. Then he gave me the warning, "If we find any bad parts in there it could easily add another $1,000 to that quote"...Dun dun daaa...:eek:
Poop, I wish I had a garage and a spare weekend.
Toyota of Inver Grove Heights - 10 hours labor, $80 parts ...
Their not replacing enough parts to do the job correctly, IIRC the parts to do a proper job are ~$300 at dealer pricing.
I'm in Iowa, (fort dodge) and could help you out with this, but can't travel out of town because I'm on call.
I'd do it for pizza and beers- but you'd have to get down here and bring the parts.
It's not nearly as hard as it seems though. I certainly wouldn't pay shop hourly rates to have it done- unless I had money burning a hole in my pocket.
x2. $80 probably only covers felts and backing seals. That is not a proper way to fix this.
PS, do not take this to a shop that has 'never done one'. The learning curve here is steep. It took me a full day to do the drivers side on mine (first timer!) and about 2.5 or 3 hours to do the passenger side. You'll be paying for the mechanics learning curve.
Seriously, with two guys with average mechanical skills you can get this done in an afternoon easy, providing one of the guys has done the job before. You get one guy working on tear down, while the other guy is getting things ready and assembling.
There you go.
Call Cruiserdan today(1-800-432-6668 then extension #8), and tell him you need "everything" for the front axle job. He'll have it on the way and you can count on the package being complete. i would recommend you replace the knuckle studs with the updated type. You need 8. Dan will know exactly what you want.
That's cool Doc, and a great offer. Are you really a Doc? Quite a few here on mud.
Here is my other bias about this job.
There isn't enough money to pay anyone to do this job right. That's why you have to do it yourself. Obviously a bit of an overstatement, but unless it's going to a Cruiser specific shop, they will mess up some portion of this job. Only you will take the time to see it done correctly.
Take Doc up on his offer, and count on a full day. Buy him a nice present afterward, and a good lunch. It will be well worth it.
I'd love to have you down for a wrenching session, but you might contact some of those in the CAC (cruiser assistance club) locally or Poser (I think he has a shop??) just out of the sheer convinience of not having to drive 4 hours to get to my place (takes about 4 hours from my door to the mall of america).
But, you are sure welcome down here if you can't seem to find anyone up there to give you a hand.
