I think i ruined a perfectly good landcruider
Placerville, CA
I think i ruined a perfectly good landcruiser
I went from 88inch wheel base to 102.5
Before and after. What do you think
Damn, you've got approach angle plus now. I wouldn't say you ruined a perfectly good Cruiser; far from it, actually. But you might ruin some perfectly good fenders unless you trim them. ;)
Just flip the front springs back around and have your front driveshaft shortened. Keep the shackle reversal by pulling the military wrapped spring, flip it, and redrill the center pin hole for that leaf. Simple and brings the front end back around. I didn't like mine either, but I stretched the front about 7 inches, now it is out 3.5 from stock. My 38" tires make it look a lot more centered. Bigger tires would help you too.
I'd flip the front springs but thats me, I'd also look at the loose nut behind the wheel;)
Hi All:
If the rig is just for "mall-cruising" then yes, you've f*&ked it good!
But if you 'wheel hard-core, then the rig is just getting better! :beer:
My only complaint is that your rear wheelwell cut-out is a bit "crude." ;p
Regards,
Alan
So Neil-You went SOA! I thought you said you never would. Here is mine:
take the frount fenders off and go wheelin!!!
I didnt want to...Dave made me do it. If i don't like it it'll be for sale soon and i'll build up my 62
