I'm going to do a fairly in depth thread talking about my front axle swap so that I can get discs on my 55. There is at least one other thread but I thought I'd go ahead and do a good thread about it so there would be another. I'm putting an axle out of an fj60 under my piggie. The first step of course was to secure an axle, the second step was to order new spring hangers, spring perches, u-bolts, and any brake lines that might be needed due to missing or damaged lines (pic 1). The hangers and perches came from Proffitts the U-bolts from Man-a-Fre and I got a couple of lines from the local Yota dealer. The next step was to remove the old spring perches from the fj 60 axle grind down the old welds and prime the housing so it would be ready for new perches (pic 2).
This is an easy fix though. Option one would be to just use the linkage off a 60 or 62, option two would just be to cut each one and extend it the few inches necessary by inserting a rod inside or a sleeve on the outside. Tried to take a pic but you couldnt really see it basically 1 wheel is straight the other is turned about 3 inches in.
