- Location
- United States
lots of good parts here
Seatbelt retractors (2)....."SOLD"...........................thanks Jacob
OEM Mirror Arm c/w gasket (1)(glass beaded ready for your paint).. ..$18.00
Set of Lower Dash Pad's (3), need cleanup only.................$50.00
Tunnel Cover..................................................................$25.00
Vin Tags.........................................................................$75.00
Glovebox Door C/W lock and wire limiting strap..."SOLD".....Thanks Shane
Brake Booster( core only)..............................................$40.00
Steering Wheel (VG) condition..."SOLD"............................. Thanks Shane
Sterring Column (NO KEY).............................................$30.00
Diesel Grill Badge's (NEW)............................................ $69.00 (SHIPPED)
Kick Vents C/W pins and springs....................................$35.00
3B crankshaft pulley c/w crankshaft bolt..."SOLD"................. Thanks TJ
Fuel Tank (VG) condition...."SOLD".....................Thanks Jacob
Restored Aisin Hubs....."SOLD"........................... Thanks Scot
Used OEM Steering Box (Armstrong).............................. $30.00
Rebuilt OEM Steering Box (Armstrong)........................ $125.00
Hard Top Good condition............................................. $150.00
Misc Glass......................All Glass now spoken for...........Thanks
Front and Rear thirds (4.10).... "SOLD"............................. Thanks Charles
Front and Rear Axle Housings (bare)........................... $30.00 each
Birfs .........."SOLD"..........................................................Thanks Gerry
Front axles....."SOLD" ......................................................Thanks Gerry
Short side rear axle shaft..."SOLD"....................................Thanks Hennig
Headlight buckets...."SOLD"......................................Thanks Jesse
OEM Fuse block good condition...."SOLD"..................thanks Jacob
Front disc brake backing plates..."SOLD"...................... Thanks Robert
Large pattern knuckles c/w steering arms.................... $35.00 each
Spindles...."SOLD"...................................................... Thanks Robert
Disc brake wheel hubs....."SOLD"............................... Thanks Ken
Brake calipers (cores only)......................................... $30.00 per Pair
Pedal box c/w clutch and brake pedals.........................$ 50.00
Front shock OEM Frame mounts.................................. $ 35.00 per Pair
Rebuilt 3B Radiator...."SOLD"............................... Thanks Scot
Rear license plate holder..... "SOLD"..................... Thanks Scot
Rear "Toyota" emblem ............................................... $10.00
Running board supports...."SOLD".................................. Thanks Chris
OEM Steering Box frame mount................................... $25.00
OEM P/S pump off a 3B diesel (no bracket,no leaks)...... $90.00
***all prices in US dollars****
Lots of other peices yet...
unless indicated...shipping is extra
pictures for all available, please contact me at
tdilad@gmail.com
Best Regards
Gord
**** any or all parts can be Glass Beaded and Painted to the standard colors i use which include gun metal grey or black, for an addition charge****
tdilad@gmail.com
Best Regards
Gord
