'73 fj40 parts
Status
Not open for further replies.
NorCal
'73 and '78 fj40 parts
Drop hitch that bolts on rear cross member. I have two. $15 with 2" ball.
Two original Dunlop Sno Cruiser tires - $25 each
Great Center Arm with mounting hw - $40
'73 fj40 parts
Cowl vent doors, super nice, with springs, pins and nice gaskets $25 pair
Heater box from under dash, - $40
Great Bezel (black) - $40
Rear seat belts, weathered, but working - $25
One good rim for drum brakes only - $20
Three hubcaps, not great, 2 rear, 1 front - $20 all
Later model '75-'78 style driver's side door glass. - $25.
Four speed and matching t-case; apart and missing two bushings - $100
2f motor in bad shape, rusted, cracked crank, rods are probably good - free
2f crank, looks great, clean and from another engine - $100
2f oil pan - $50
2f head needs machining - $50
2f water pump and plastic fan with clutch - $90
Hard Top vent glass, one side has some scratches - $20
Tail light lenses in ok shape - $20 pair
While you're here, I'm looking for and may trade for these '75-'78 parts:
ambulance door strikers
rubber t-case boots (front output and shifter)
Aisin mini-truck style hubs
leaf spring shackles and pins
dual diaphram brake booster
one good original seat bottom cover
perfect bib and windshield frame
All prices obo plus a box plus shipping from 95125. Clean parts are extra. :)
If you have the "Front Fan" and "Rear Fan" switched with knobs, I'm in.
I'll take the bezel, too.
Ed 64114
It doesn't have a rear heater. It might have at one point. I'll have to look again, but I won't get back out there until Tuesday. They're yours if I've got 'em. I'll take some pics then too.
I'll take the bezel too.
It's upside down. Is that ok?
I was interested in the windshield hooks and bumpers.I have a 68 and I think I am looking for the taller bumpers?
You mean bumperettes from the back? I've got one. I'll post a pic Tuesday or so.
meant the rubber bumpers the windshield sits on.I have seen several different styles and the ones i have currently let the wiper arms hit the hood.looking for the ones that have a step in them and are a little taller.
Those are the ones I have. :)
Ed, I'd be interested in the carb core and the wiper motor. LMK
Do you have the door latches? The part on the tub that holds the door closed.
pics of selected parts
Spare tire mount - $100
Hood Hinges - $40
Vent Grill - $20
Door parts, tell me what you need and we'll work out a price. No glass. The metal itself is not even good enough for a 1/2 door.
Factory Soft Top Mounting Parts
$20 with all the hardware; both sides. One rear top bracket is very slightly bent.
What's the big nut in the top picture for? I didn't see it at SOR. [edit] It's the mount point for factory door safety straps.
Status
