nibliks 40 build...
christchurch,nz.
ok... here goes.. my build is a 40 series 3b diesel..
plans off the top of my head include a turbo with oil cooler, s.o.a, spring flip, spring reversal, roll cage, longs, toybox, power steering, tubbed rear wheel wells, raised widen front guards, pto, 60 series axles, twin lockers, amongst numerous other mods..
anyways, to get the ball rolling.. he she is as i got it..
then stripped it bare, dropped body off to metal worker mates who is doin the tubbin and a bit of cancer removal.. chassis got naked to this..
got blasted and came back, got pulled apart to start the build from scratch..
i have a power of photos and had a whole write up done when i found ya cant do it like i thought, bugger goin through that again..
oh well.. heres where i'm up to.. soa with cut and turned front with fabricated engine mounts, folded 6mm perches and 10mm u-bolt plates, tubbed body the sliders and diff hubs assembled with discs..
wheels are on as just a mock up to see how high the body sits and look at the approach angles etc..
cheers..
p.s.. any reason why i cant post more than 5 to 6 pics without effecting he first pics up? :doh:
cheers again..
Nice project,
hope to do a similar project with my other BJ42, so am very interested about your build. Keep us up to date.
As for pictures, you can only post a few, unless you buy a silver star for like 25 bucks, then you can post unlimited pics.
Cheers and good luck with the truck,
Deny
Oh, question, did you outboard the springs, or cut into the diff to fit the 60 axles on the 40? Pics? thanks
silver star aye? oh very well... may have to look into that in the near future..
as for 60 diffs, yeah, using 60 rear leaves and 70 series fronts ( longer = more artic :D ) and have outboarded the spring mounts... i thought it would be a bit tidier than cutting into the 'pumpkin' (diff housing).. this first pic, you should just be able to see thee outborded front mounts..?
then this next pic is of the front drivers side u-bolt setup.. i have all the rest goin around the diff housing itself, same as a hilux setup but this side proved to be tricky as the turning of the housing to align the driveshaft left the square ublot needed to sit flush with square housing was all whack.. heres a pic of my solution any hows.. :)
Wow!
You should throw together a simple website (free with most e-mail accounts), one page with your write-up and pictures. Then you can "reference" the pictures from here without "storing" them here...no limit to the pics you can include in your posts. You still get full sized pics in the post.
It looks like you cut plates to close in the differential, is that just to keep them clean inside or is it for alignment?
Excellent timing. I'm selling my trail truck back to the original owner and going to buildup the '81 BJ42 into what the trail truck had- flat springover(shackle reverse, rear FJ55 springs, stretch things reasonably), 35-37s, 4w discs, power steering, york, add a front locker (rear already ARB), and a toybox (the new bit). Turbo too.
Goal is to keep it streetable and with the increased fuel capacity let it do some fair weather expedition stuff as well as medium-harder trails (Cali mtns, Moab, mountains around Oregon, SNOW).
What are your plans for the fuel tank? I am thinking to keep the tank underneath will have to be custom. I want to add about 10 gallons as well and get into the 500-600 mile range.
ok.. sorry for any random order.. got a lot done over a long time and much to put down and catch up on.. so here goes..
started with the donor as ya saw above.. stripped tub and deloomed everything and removed body from chassis to put new wells and fix rust in tub, and send chassis off to sandblasters for a quick jiffy up..
pre blast..
post blastin...
repaired rust in drivers well
and the new wells..
got the power steering, pto, wider axles, motor, gearbox and transfer from a donor vehicle..
new chassis mount fabbed up..
new spring hangers for 75 series greasable pins used to enable both larger bushes and the ' more strength' issues..
spring flip and bigger axles with shackle reversal required outboarding and relocating all spring mounts.. i'm using rear 60 series springs on the back, and 70 series springs up front, all std with leaves added/ removed as required..:)
rear bar on, diff in soa position and springs in..
engine, gearbox and transfer in (for mock up purposes at the mo) and front sitting soa..
turn on diff done, rear perches welded up, off centred the locator pins to grab that extra little bit of wheel base and better departure angle..
cut the front for the turning..
and success! phew, wasnt lookin forward to it, but ended up being easier than i thought.. :D
so the front cuts were lined up and then welded.. hubs reassembled with new bearings etc, and the new vented disc put on.. (keeping in mind i still have to paint diffs.. )
the front drivers side of the housing was a bit tricky having it turned, the housing being square and off level due to the turn, was over come by mounting the original u-bolt keeper underneath.. i wasnt too keen on bending u-bolts or cuttin the housing.. there is still enough room in between the springs and the nugget housing for the u-bolts too.. keeps it looking a bit more factory/tidy..
so this is with a pair of a mates 35's on, soa done.. just for curiosties sake i did this.. ;) next step off to mr certifiers..
this is my approach angle with 35's on..
and the departure angle.. nb.. i havnt got the longer greasable shackles on at the mo.. my cobber with the 35's borrowed them for his rig..:rolleyes:
well, thats a quick catch up session i thinks..
oh, i'm gonna keep the stock fuel tank and in the worst case scenario, if i'm headin on a long jaunt, i'll just take a jerry can..
forgot to add i'm gonna chuck a turbo on it too.. a tc05.. i have gotten one after reading threads on here but alas got one with a 4 boltflange and not the 3 bolt version.. :crybaby: gutted...
am i able to unbolt the housing/flange bit to put on a 3 bolt type or just start over? or weld the sucker? i have 'ole rusty' which i have as a play thing while i build this truck up.. might just weld onto 'ole rusty' and get aother for the build.. would that be easier?
'ole rusty'...
The build is looking good. Can't wait to get mine to Idaho so I can start on my minor resto.
well all went well with mr cert type dude... he was happy with all the mods done and the weldin on all the perches and gussets etc..
:D
got the tub just sittin on the chassis last night..
the rear will come up a bit when i put the slightly longer shackles back in and possibly an extra leaf or so aswell.. the front will lower a bit too when the rest of the body panels and crap go on, and a slightly longer set of leaf springs... thus bringing the tub back to level and shackle angles all lovely jovely.. :wink:
will have to get a big tyre on a rim to test out the new forming required for the rear arch.. the new location of the rear diff really stands out in comparison to where the original sat.. :eek: .......:flipoff2:
and lastly in my quick update, the rear diff from a 60 does have a bit of extra width huh?! excellent..
:bounce: :bounce2:
spacer for inverted steering arm...
milled inverted arm..
and bolted up, but will prob go to capscrews and nordlocks when the time comes.. still has two sets of the cone washers in there..
drilled chassis rail to take the 60 series power steering box and put in the crush tube..
mocked it up quickly with some load spreading plates made from 5mm plate.. also taked a wee weld onto the crush tube to hold em there if i ever take the box off..
shaped the plates slightly and with 10mm longer than the std 60# bolts, bolted together the lot and my mate welded it up quickly.. will weld tops and bottoms of l.s.p's later..
outer of rail..
and inner..
also pulled apart the 60# front disc calipers and gave them a sandblast, pulled out all seals etc, honed out the bore, new pistons and seals, painted and reassembled..
now i have a nasty wee dilemma.. am trying to come up with a steering shaft that goes from the uni under the column across the chassis rail and into the uni at the power steering box input.. it needs to be 90mm longer than a std 60's.. anyone know of such a std item? could get one made up but have been quoted around $200 to put a spline on each end of the shaft... :eek: thought it may be cheaper to buy a second hand one if there is one available and cuttings not really an option as am unclear as to whether it is legal for nz roads to do this.. will ring cert chap anyways too...
anyone know?
cheers..
nib
That thing is sweet. I've got a steering arm idea for my SOA now. Can anyone tell me the thread pitch on the knuckle studs? What do you mean by cap screws and nordlocks? Sorry for the 20 questions. Very nice.
