MAF Rotors
Madison, NC
I have to replace my rotors calipers and pads:doh: , I've been looking around at some rotors and found that MAF had them for around $65 a piece. Has anyone ever used these before? I would love some feedback if anyone has. I'll try to post some pics of the brake rebuild when I get started. Thanks
I bought a set from advance auto 45 each but the holes for the studs where slightly larger, the hub hole was the same so I'm going to rum em anyway. I'll check them later when i rebuild the birfs.
Youv'e got THE WRONG ROTORS. I would not use these as they are intended for the later design whereas the stud goes through the rotor. I had the same problem from Advance Auto....books showed all FJ40 from 9/75 though current use the same rotor which IS WRONG. I went through this some time ago and ended up buying mine from the dealer for around a buck a piece. I later found a thread that said they were available from other sources for considerably less.
Wade through this link: https://forum.ih8mud.com/showthread.php?t=53129
and more specifically: https://forum.ih8mud.com/showthread.php?t=34773
