Finally....A/C Mod..freezing A/C.. I did it!
Dallas, Texas
Folks for years my A/C has been on the warm side. Never cold. My kids suffered in back so I added an Aux Fan. That did help..but not this year with 104 degree days in Texas...my kids still suffered. Then I added Limo tint...no change. Then a new expansion valve still only slightly cooler.
As I write this... my truck is on it's 3rd week of getting a major 90,000 tweak.
Valve job, knuckles, supercharger mod, PHH, and overhaul of A/C. it's is almost done. I asked my mechanic under no condition do I want my truck back without modifying the lousy factory A/C.......I said put a bigger compressor in it or something but FIX IT!
He called me Friday. He said he stuck a motor fan from a GMC DENALI in my compressor after some rigging of the stock unit to fit it. He calls me from the middle seat as he is being driven around and says in his texas slang
"Steve..I got er' fan blowing 250 RPM higher than factory and she's 48 degrees
in the back seat...is that cold enough fer ya"
He did it...in 3 days...... after ten years of moderate A/C I 've got a stronger fan and COLD A/C. This is what I was looking for...I will get her back this next week...and I'm hangin meat in it by God!!
airlaird
Do you mean the condenser? If so, where did he mount it?
Whoops YES, I meant the condenser under the passenger dash area.
airlaird
Lets hope he didn't move the condenser under the dash panel.
I think you meant the evaporator. Keep us updated on how well it works.
I am very surprised that moving more air across the evaporator made things any cooler (usually the opposite happens).
I can see how you might not have been getting much air flow to the rear seats though...the fan would help in that respect.
Hope it works for you, its been mighty hot in Texas this year.
Evaporator, condensor, evaporator..moderator...one of those words that ends in "or";-)
airlaird
I know its confusing. I'm not trying to "correct" anyone, just saying I hope the fan thing works for you and the kids.
The A/C in mine works great at highway speeds...and a more powerful blower motor might help get that cool air to the rear of the vehicle. At idle speeds...it pretty much sucks, it is one area that I am disappointed in the Cruiser.
East Texas summers are very hot and humid, its a challenge for an A/C system to keep up.
AC Improvement
Airlaird,
Would you mind identifying or explaining exactly what he did. This seems to be a major improvement that a lot of people would benefit from..
thanks
chris
Funny Chris he would only wink at me and say " I got some tricks I can do..trust me"
Obviously I am ingnorant about the A/C terminology (see ALL my previous posts ;-). I walked in to his shop very disgruntled about the A/C system in the LC (mainly city stop-and go driving) I insisted he mod something stronger....he knew about the GMC mod before I could even explain it to him.
I'll have to wait and see what "gives up" when I get it back.
airlaird
airlaird
Valve job at 90k? Whats up with that??
Just summarizing..no valve job. After I replaced the plugs and Dist wires, I found oil puddling as I took off the dist wires. Each plug has a round bushing/gasket at the top of the "cylinder" where the boot goes in. there was oil puddling at the top of the #2 bushing. So I simply asked him to replace all 6 bushings and the Valve cover gasket for Preventive
Maintenance,
airlaird
Didn't you install an aux fan in front of the radiator to help with the cooling or was it someone else?
let us know what he did Steve...
My AC is ice-cold, never been recharged.. Pretty cool. (no pun intended)
The lack of humidity in the Provo area probably helps that.
East Texas is humid and this seems to make it even hotter--you sweat just walking outside!!!!
Interior fan-wise, seems like several folks have opened the fan up to find the blades clogged with 10 years of crud and even a mouse nest or two. If your A/C is not up to snuff, consider this easy check and clean to ramp up air flow. My factory setup blows ice cubes even at idle in 95 degree heat. We don't have the humidity, but it seems to be particularly strong. I also have a habit of spraying down the radiator and A/C condensor with degreaser and spraying out the fins every couple years. Did this once on a Subaru and measured something like 16 degree cooler air at the dash vents for 15 minutes work. If you can't exchange heat directly to air (fins coated with road grime), or have partly blocked fan blades, it will have a dramatic impact even if the system is otherwise fine.
Makes me wonder if he found your fan full of the usual debris and knew full well that would improve things.....
DougM
But if he replaced the stock fan with one from a Denali, it would have had the same effect. It would have been clean (I hope) when he stuck it in there. I'm sure the new fan is stronger though.
Congratulations on the chill factor!
IdahoDoug- Could you explain the procedure for cleaning the crud/gunk off of the fan blades. Meaning more how you access them?
Is it simply undo the bolts that retain the fan to the housing and drop it down.... wipe them clean... and reinstall?
I never thought of that. Actually felt there is a filter that would catch the debris before that happened. I agree after 10 years that the fan blades are probably not clean.
Steves mechanic is a friend of mine and we talked at length about this mod. He takes a GMC blower motor and attaches the Toyota fan cage to it. It appears that the GMC mootor turns 250 RPM faster than the Toyota putting out more air. The exact CFM difference is unknown, but it does move a bunch more air.
Well...he is a true artisan ;-)...he still has the truck..going into it's 4th week. that's fine with me....he can have it for 5 weeks until he fixes all the annoying issues I have with it. I gotta company car...so I can do without my LC for another week. Sooo, I can't give you a real world analysis....yet
airlaird
