Clunking Slider Fix
КАГІҒОЯИІА
Hey folks,
This has been a long time coming, mostly because I forgot, but I did this pic for Boston Mangler so I figured I would spread it out to everyone.
I mentioned I would post a pic when I first did this so...here it is :D
My sliders hit the pinch weld a little on the drivers side creating a "clunk" that bugged the living sh*t out of me.
Here is my fix...
I folded a 10" piece of pipe strapping in half to about 5", pounded it flat, drilled a hole big enough to fit over the top of the U-bolt in the end where the two ends of the strap came together and hung it from the bolt between the FRONT slider bracket and the frame to about 1/3 to 1/2 of the way down the frame.
The strap I used was a 10" piece of galvanized pipe strapping, about 1/16" thick (folded in half to 1/8")
When you tighten everything down, the bottom of the bracket tightens closer to the frame, which, in turn, makes the slider sit just about 1/8" lower from the pinch weld, thusly eliminating said "CLUNK"!
Hope this helps anyone who has this issue.
:beer:
Thanks Jeb
P.S. Which art gallery was it that you said was showing some of your best work at? Will this diagram be there? :D
Boston Mangler said:
Thanks Jeb
Gotta luv it:)
Well, it got the point across! :D
Thanks man
Thanks for the info Jeb
I just got done doing mine as well. I put 2 washer (for each bolt) between the slider and the frame to lower the passenger side down a little and i cut a piece of 3/16" The pic says 5/16" but its wrong) flat stock i had and mounted it similar to your way for the drivers side.
Here are my pics:
Unfortunately, my clunk is still there but i am SURE that it isnt the sliders to i must continue searching for the noise! :frown:
